SIMPLE for viscous NavierStokes
Old   July 11, 2005, 12:44
Default I have modified the UEqn.H and
Juergen Almanstoetter
almanstoetter is on a distinguished road
I have modified the UEqn.H and hEqn.h in buoyantSimpleFoam to represent steady laminar viscous Navier-Stokes:
volTensorField gradU = fvc::grad(U);
tmp<fvvectormatrix> UEqn
fvm::div(phi, U)
- fvm::Sp(fvc::div(phi),U)
- fvm::laplacian(2*mu+lambda, U)
UEqn().relax();
solve
UEqn() ==
fvc::div
mu*gradU.T()+lambda*I*tr(gradU)-(mu+lambda)*gradU
- fvc::grad(pd) + fvc::grad(rho)*gh
fvScalarMatrix hEqn
fvm::div(phi,h)
- fvm::Sp(fvc::div(phi), h)
- fvm::laplacian(k/Cp, h)
hEqn.relax();
solve
hEqn ==
fvc::div(phi/fvc::interpolate(rho)*fvc::interpolate(p))
- p*fvc::div(phi/fvc::interpolate(rho))
+ ((lambda*I*tr(gradU)+mu*(gradU+gradU.T())) && gradU)
Do UEqn.H() and UEqn.A() in pEqn.H still give the required diagonal and off-diagonal entries ? Has the field phi to be extended to use the SIMPLE algorithm in pEqn.H ?
Juergen
almanstoetter is offline   Reply With Quote
Old   July 11, 2005, 13:15
Default UEqn.H() will not be correct a
henry is on a distinguished road
UEqn.H() will not be correct as you have currently formulated UEqn. You need to move the fvc::div term from the UEqn solve statement to the UEqn construction:
fvm::div(phi, U)
- fvc::div
UEqn().relax();
solve
UEqn() == - fvc::grad(pd) + fvc::grad(rho)*gh
henry is offline   Reply With Quote
Old   March 9, 2006, 23:23
Default Hi friends, I also want to
Guoxiang
liugx212 is on a distinguished road
Hi friends,
I also want to use the buoyantFoam case to simulate the sequestration. It means that I need add the Darcy term and source term in solver. But I am not sure what do I do. Could you please give some advice?
Thanks advance.
Guoxiang
liugx212 is offline   Reply With Quote
Viscous heating Pipin FLUENT 3 July 14, 2008 12:05
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai Main CFD Forum 0 April 18, 2007 03:48
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai FLUENT 0 April 13, 2007 23:17
navierstokes equation raj Main CFD Forum 2 August 23, 2006 06:26
Navierstokes solver vivek Main CFD Forum 2 July 27, 2005 06:00
