Job Scheduler for parallel processing
Old   March 6, 2006, 16:22
Default Hello friends I saw in the
kumar
kumar2 is on a distinguished road
Hello friends
I saw in the manual ( Users manual , U-63 , damBreakCase ) that OpenFoam parallel runs can only be executed from the command line. Does this mean that we cannot use a job scheduler ?
Thanks in advance
kumar
kumar2 is offline   Reply With Quote
Old   March 7, 2006, 02:04
Default Can anyone please give some in
kumar
Can anyone please give some inputs ?
thanks
kumar
Old   March 7, 2006, 03:37
Default You can easily run OpenFOAM us
Francesco Del Citto
fra76 is on a distinguished road
You can easily run OpenFOAM using a job scheduler, even for a parallel job. Here follows a simple script I used with Torque (PBS).
I hope it can be helpful!
#!/bin/bash
#PBS -N fiume
#PBS -j oe
#lamboot -v $PBS_O_MACHINES
cd $PBS_O_WORKDIR
export LAMRSH=ssh
lamboot $PBS_NODEFILE
mpiexec interFoam <rootcase> <casedir> -parallel </dev/null> output.out 2>&1
lamhalt -d
fra76 is offline   Reply With Quote
Old   March 7, 2006, 03:38
Francesco Del Citto
#!/bin/bash
#PBS -N jobname
#PBS -j oe
cd $PBS_O_WORKDIR
export LAMRSH=ssh
lamhalt -d
Francesco Del Citto
#!/bin/bash
#PBS -N jobname
#PBS -j oe
cd $PBS_O_WORKDIR
export LAMRSH=ssh
lamhalt -d
Old   March 7, 2006, 04:12
Default HI Francesco, I tried your
Pierre Maruzewski
pierrot is on a distinguished road
HI Francesco,
I tried your script BUT :
LAM attempted to execute a process on the remote node "node191",
but received some output on the standard error. This heuristic
assumes that any output on the standard error indicates a fatal error,
and therefore aborts. You can disable this behavior (i.e., have LAM
ignore output on standard error) in the rsh boot module by setting the
SSI parameter boot_rsh_ignore_stderr to 1.
LAM tried to use the remote agent command "ssh"
to invoke "echo $SHELL" on the remote node.
*** PLEASE READ THIS ENTIRE MESSAGE, FOLLOW ITS SUGGESTIONS, AND
*** CONSULT THE "BOOTING LAM" SECTION OF THE LAM/MPI FAQ
*** (http://www.lam-mpi.org/faq/) BEFORE POSTING TO THE LAM/MPI USER'S
*** MAILING LIST.
This can indicate an authentication error with the remote agent, or
can indicate an error in your $HOME/.cshrc, $HOME/.login, or
$HOME/.profile files. The following is a (non-inclusive) list of items
that you should check on the remote node:
- You have an account and can login to the remote machine
- Incorrect permissions on your home directory (should
probably be 0755)
- Incorrect permissions on your $HOME/.rhosts file (if you are
using rsh -- they should probably be 0644)
- You have an entry in the remote $HOME/.rhosts file (if you
are using rsh) for the machine and username that you are
running from
- Your .cshrc/.profile must not print anything out to the
standard error
- Your .cshrc/.profile should set a correct TERM type
- Your .cshrc/.profile should set the SHELL environment
variable to your default shell
Try invoking the following command at the unix command line:
ssh node191 -n 'echo $SHELL'
You will need to configure your local setup such that you will *not*
be prompted for a password to invoke this command on the remote node.
No output should be printed from the remote node before the output of
the command is displayed.
When you can get this command to execute successfully by hand, LAM
will probably be able to function properly.
LAM 7.1.1/MPI 2 C++/ROMIO - Indiana University
Lamnodes Failed!
Check if you had booted lam before calling mpiexec else use -machinefile to pass host file to mpiexec
So can you help me ???
Pierre
pierrot is offline   Reply With Quote
Old   March 7, 2006, 04:38
Default Hi Francesco Thanks a lot for
kumar
Hi Francesco
Thanks a lot for the script. Let me give it a try.
Hi Pierre , I will get back after trying out Francesco's script.
Regards
Kumar
Old   March 7, 2006, 04:53
Default This is qhat I get while execu
Francesco Del Citto
This is qhat I get while executing commands contained in the script from an interactive job:
[carlo@epsilon runFiume]$ qsub -I -l nodes=2
qsub: waiting for job 2270.epsilon to start
qsub: job 2270.epsilon ready
Executing: /server/carlo/OpenFOAM/OpenFOAM-1.2/.bashrc
Executing: /server/carlo/OpenFOAM/OpenFOAM-1.2/.OpenFOAM-1.2/apps/ensightFoam/bashrc
Executing: /server/carlo/OpenFOAM/OpenFOAM-1.2/.OpenFOAM-1.2/apps/paraview/bashrc
[carlo@node2 ~]$ cd $PBS_O_WORKDIR
[carlo@node2 runFiume]$ export LAMRSH=ssh
[carlo@node2 runFiume]$ lamboot $PBS_NODEFILE
LAM 7.1.1 - Indiana University
I guess the proble is the configuration of ssh/rsh in your cluster. I've configured my cluster so that a group of users can access with ssh from node to node without beeing asked for a password. This can be made easily because nodes share a NFS file system on the server, and the autentication is provided by a NIS server. So, the only thing I've done is adding the public key conatined in ~/.ssh/id_dsa.pub to the .ssh/authorized_keys? files.
This allows LAM to use ssh without be asked for the password. Another issue can be a possible error while ssh tries to forward X11 connection. This can be avoided with
export LAMRSH="ssh -x"
The standard behaviour of LAM distributed with OpenFOAM is trying to connect from a node to another using rsh. If you can access a node with rsh, you can try deleting the export LAMRSH line from the script.
For debuggin purposes, you can try this:
lamboot -v $PBS_NODEFILE
And post the result.
Francesco
Old   March 8, 2006, 05:15
Default Dear Francesco, I tried lamb
Pierre Maruzewski
Dear Francesco,
I tried lamboot -v $PBS_NODEFILE
And that's the result :
n-1<5503> ssi:boot:base:linear: booting n0 (node223)
n-1<5503> ssi:boot:base:linear: booting n1 (node224)
ERROR: LAM/MPI unexpectedly received the following on stderr:
------------------------- /usr/local/Modules/versions --------------------------
3.1.6
--------------------- /usr/local/Modules/3.1.6/modulefiles ---------------------
dot module-cvs module-info modules null use.own
------------------------ /usr/local/Modules/modulefiles ------------------------
NAGWare_f95-amd64_glibc22/22 goto/0.96-2(default)
NAGWare_f95-amd64_glibc23/23 gsl/1.6(default)
acml/2.5.1(default) intel-cc/8.1.024
acml_generic_pgi/2.5.0 intel-fc/8.1.021
acml_pathscale/2.5.1 mpich-gm-1.2.6..14b/pathscale-2.3
acml_scalapack_generic_pgi/2.5.0 mpich-gm-1.2.6..14b/pgi-6.0(default)
ansys/10.0 mpich_pathscale/1.2.6..13b
ansys/10.0_SP1(default) mpich_pgi/1.2.6..13b
cernlib/2005(default) nag/21
fftw-2.1.5/pgi-6.0 pathscale/2.0(default)
fftw-3.0.1/pgi-6.0 pathscale/2.3
fluent/6.0.20 pgi/5.2(default)
fluent/6.2.16(default) pgi/6.0
gcc/4.0.2
LAM attempted to execute a process on the remote node "node224",
*** MAILING LIST.
probably be 0755)
running from
standard error
ssh -x node224 -n 'echo $SHELL'
n-1<5503> ssi:boot:base:linear: Failed to boot n1 (node224)
n-1<5503> ssi:boot:base:linear: aborted!
n-1<5508> ssi:boot:base:linear: booting n0 (node223)
n-1<5508> ssi:boot:base:linear: booting n1 (node224)
3.1.6
gcc/4.0.2
*** MAILING LIST.
probably be 0755)
running from
standard error
n-1<5508> ssi:boot:base:linear: Failed to boot n1 (node224)
n-1<5508> ssi:boot:base:linear: aborted!
lamboot did NOT complete successfully
Old   March 8, 2006, 05:42
Default Look at the message: Try
Francesco Del Citto
Have you tried that command?
Another issue is the "module" command (it seems you have almost the same configuration of my cluster...). Look at the result of thees commands:
[francesco@epsilon ~]$ module av
---------------------------- /usr/local/modulefiles ----------------------------
--------------------------- /opt/Modules/modulefiles ---------------------------
gnu gnu41 intel8 intel9 lam mpich openmpi
[francesco@epsilon ~]$ module av 2>/dev/null
This means that the command "module available" print its output on the standard error stream. LAM returns an error if there is any output in the standard error while executing remote shell command (ssh or rsh). That's why they suggest to use "ssh -x", because it doesn't even try to open an X connection.
I guess you have the command "module available" in your ~/.bashrc or in the global /etc/bashrc (I'm supposing you're using bash). You have to remove that command, or substitute it with "module available 2>&1", redirecting stderr to stdout. So it should not confuse LAM anymore.
Furthermore, I think you can always remove LAM distributed with OpenFOAM an install it from source, activating the support for Torque, so that neither rsh nor ssh would be required. I've done it, and it works fine with other mpi applications, but I've never tried with OpenFOAM.
I hope this can help you.
Francesco
Old   March 8, 2006, 06:09
Default Hi Francesco, It's runnig p
  #11
Pierre Maruzewski
Hi Francesco,
It's runnig perfectly thanks to "module available 2>&1"
Pierre
job scheduler qq Main CFD Forum 7 January 1, 2009 23:04
parallel processing V 3.24 Phil D Siemens 3 November 10, 2007 04:31
parallel processing mvee FLUENT 3 September 18, 2007 03:18
Parallel Processing AJ Siemens 1 September 10, 2005 12:02
MPI for parallel processing Chuck Leakeas Main CFD Forum 4 January 14, 2002 20:18
