Boundary scalar field
Old   March 6, 2006, 03:53
Default Hi, I'm modifying the RNGkEps
David Segersson
segersson is on a distinguished road
I'm modifying the RNGkEpsilon turbulence model to use wall functions with non-uniform roughness. Since the roughness coefficient (ks) is only needed on the boundary I would like to include a "boundaryField" for this variable among the members of the turbulende model (it seems unnecessary to create a volScalarField when only values on the boundaries are needed). Can anybody tell me how to create and use this kind of field or fieldlist? After some looking in Doxygen I tried GeometricBoundaryField, but it does not seem to work (at least not the way I'm using it).
Regards
David
segersson is offline   Reply With Quote
Old   March 6, 2006, 04:22
Default Use - FieldField : a field fo
Mattijs Janssens
mattijs is on a distinguished road
Use
- FieldField : a field for every patch, no internal field reference. Reference counted.
or
- PtrList<field>. Same but not reference counted.
You construct them with the number of patches as argument and then setSize the members to be of the size of the patch.
mattijs is offline   Reply With Quote
Scalar Field Residual dak81 OpenFOAM Running, Solving & CFD 3 February 13, 2008 01:48
[mesh manipulation] Mesh refinemt by scalar field zurdo OpenFOAM Meshing & Mesh Conversion 3 January 9, 2008 05:15
MeshPhi for scalar field in 14 gone tehache OpenFOAM Running, Solving & CFD 0 June 18, 2007 06:20
Passing scalar field across processors ankgupta8um OpenFOAM Running, Solving & CFD 1 June 7, 2006 03:32
Set a fixed value of scalar in flow field. Ke Su FLUENT 0 June 20, 2003 14:47
