Mixing elbow case water heat transfer calculation buoyantFoam
Old   January 14, 2006, 09:25
Default I tried to reproduce the mixin
Benjamin SAUTHIER
benyamin1 is on a distinguished road
I tried to reproduce the mixing elbow calculation presented in the Fluent tutorial.
It is about the mixing of 2 inlet water pipes at 2 different temperature (water at 25/40 degC Velocity = 0.2 & 1m/s; pipe diameter 40cm/10cm)
I performed a potentialFoam calculation. Then I successfully converged a calculation using simpleFoam (note: I couldn't have turbFoam converge on this case).
Now I want to do a heat transfer calculation and this is where I have a problem. It seems I cannot use simplebuoyantFoam solver because the thermophysical properties are only for perfect gases. Am I right? How can I use water properties. I've noticed that thermophysical properties for water are already in OpenFoam but I don't know if I have to recompile a new solver (how?) or not to use the water properties.
Thx for your help.
benyamin1 is offline   Reply With Quote
Fluid Flow and Heat Transfer in a Mixing Elbow atzaru OpenFOAM Running, Solving & CFD 10 April 20, 2017 23:36
Solver for heat transfer calculation with water media benyamin1 OpenFOAM Running, Solving & CFD 6 January 27, 2011 04:26
Heat transfer/ Temperature calculation Novice FLUENT 0 July 3, 2008 07:24
Turbulent heat transfer calculation Frank Rubensdorffer FLUENT 2 May 29, 2002 14:37
Heat transfer: test case Pawel FLUENT 0 October 24, 2001 09:16
