Question about new case
Old   November 26, 2005, 08:54
Default Hi, everyone. My question i
Efimenko Evgenii
evgenii is on a distinguished road
Hi, everyone.
My question is about new case.
I wrote a new solver, compiled it with wmake, it works correctly. I copied configuration files from SYSTEM folder to USER folder, changed all configuration files to my solver configuration files keeping structure.(as it was described in Guides and some posts here).
Then I create a new case. If I don't change application class and it remains for example "icoFoam" it works, it really does. But in case browser it creates fields U and p instead of E and H I'm using in my solver. And if I change it, I receive message "invalid class application".
Should I register my solver somewhere else?
I understood (viewing some posts) that some people've faced this problem, but I still don't have clearance if it was succesfully solved.
evgenii is offline   Reply With Quote
Old   November 26, 2005, 09:20
Default icoFoam.cfg (or one of the fil
Mattijs Janssens
mattijs is on a distinguished road
icoFoam.cfg (or one of the files it pulls in) specifies that it needs U,p. My guess is that your configuration files haven't been adapted correctly or haven't been read in.
When you create a new case and you have the pulldown for the application type does it show your new solver? If not it hasn't read in your config files.
I think it scans
$WM_PROJECT_USER_DIR/applications/solvers
for new solvers and
$WM_PROJECT_USER_DIR/applications/utilities
for new utilities.
mattijs is offline   Reply With Quote
Old   November 29, 2005, 15:56
Default Hi, Efimenko Evgenii, you can
VVqf
vvqf is on a distinguished road
you can change the .gif file?
I mean have you substituted gif pictures for U and p with E and H ?
If so, could you please tell me:
1. where do the "iconURL" directory lie? I can't find it.
2. Are there any requirements for the gif picture file, such as size?
Thanks.
vvqf is offline   Reply With Quote
Old   December 2, 2005, 07:49
Default Hi, Mattijs Janssens. I've tr
Efimenko Evgenii
I've tried to put my .cfg files to
but it still don't see it.
What should I do?
I don't have any thoughts about it.
Old   December 2, 2005, 10:28
Default FoamX will scan for XXX/Fo
Mattijs Janssens
FoamX will scan for
XXX/FoamX/XXX.cfg
starting under
$FOAM_SOLVERS
and
New BC for the case ivanyao OpenFOAM Running, Solving & CFD 1 October 29, 2008 04:04
Help! Should I use LES in this case. Thanks. Feng FLUENT 4 April 25, 2008 17:04
Cloning a case or creating a new case for 16 processes mellanoxuser OpenFOAM Running, Solving & CFD 0 February 8, 2008 16:52
Problem seeing new case in case browser alan_fergus OpenFOAM Pre-Processing 9 June 22, 2006 03:46
Anyone who can help me for this case ? Adam FLUENT 0 September 30, 2005 10:50
