Is this meaningful to run parallel in this way? |
May 13, 2009, 06:59 |
Daniel WEI (老魏)
Rep Power: 21 |
Hi Forum,
Bcoz I have difficulties to insert "-parallel" option to my supercomputer (They did not let me execute mpirun command directly), so I am trying the possible solution like this: Suppose I have a 4-cores Intel CPU personal computer, Can I execute the mpirun command without "-parallel" option (without decomposePar first), like this: mpirun -np 4 `which icoFoam` -case $FOAM_RUN/tutorials/icoFoam/cylinder > log & Is this meaningful? Please help.. Thank you.
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
May 13, 2009, 09:04 |
Kerstin
Rep Power: 17 |
this means you run your case as a single case 4 times on 4 CPUs. I think that's not what you want to do. Kerstin |
May 13, 2009, 09:30 |
Daniel WEI (老魏)
Rep Power: 21 |
Okay, how then can I achieve this goal??
I am using a super computer managed by lsf system, instead execute Code:
mpirun -np 4 icoFoam -parallel > log &; Code:
bsub ./c.lsf Code:
APP_NAME=snode NP=16 RUN="`which icoFoam` -case /home/users/temp/OpenFOAM/temp-1.5/run/tutorials/icoFoam/cylinder -parallel > log" Code:
attempt to run parallel on 1 processor.....FOAM aborting... What can I do? Please The question is now "How to use lsf system to manage the foam Job"
May 13, 2009, 10:40 |
Daniel WEI (老魏)
Rep Power: 21 |
I know in Fluent, there's option "-lsf" and "-mpi=", eg.
bsub -I fluent 3d -lsf but OpenFOAM, only gives a "-parallel" option, is is possible to provide such more convenient option?
Script to Run Parallel Jobs in Rocks Cluster | asaha | OpenFOAM Running, Solving & CFD | 12 | July 4, 2012 22:51 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Parallel Run on dynamically mounted partition | braennstroem | OpenFOAM Running, Solving & CFD | 14 | October 5, 2010 14:43 |
MPICH Parallel Run Error on the Windows Server2003 | Saturn | CFX | 3 | August 29, 2006 08:42 |
Windows 64-bit, Distributed Parallel Run Issues... | Erich | CFX | 3 | March 28, 2006 16:36 |
