BubbleFoam alpha equation
Old   June 23, 2005, 05:48
Default Hello, I have a question on t
Alberto Passalacqua
I have a question on the implementation of the eulerian model in bubbleFoam.
Why the alpha equation has been implemented as:
fvScalarMatrix alphaEqn
fvm::ddt(alpha)
+ fvm::div(phi, alpha, scheme)
+ fvm::div(-fvc::flux(-phir, beta, scheme), alpha, scheme)
and not as
fvm::ddt(alpha)
+ fvm::div(phia, alpha, scheme)
Best regards,
Alberto
Alberto Passalacqua
Old   June 23, 2005, 05:51
Default To maintain boundedness of alp
henry is on a distinguished road
To maintain boundedness of alpha at the 1 limit as well as the 0 limit.
henry is offline   Reply With Quote
Old   June 23, 2005, 07:27
Default Thank you Henry. Alberto
Alberto Passalacqua
Thank you Henry.
Alberto
Alberto Passalacqua
Old   August 24, 2005, 02:55
Default Could anyone explain the deffe
Sang Yong Lee
sanglee is on a distinguished road
Could anyone explain the defference between,
fvm::ddt(rho,e), and rho*fvm::ddt(e) ?
sanglee is offline   Reply With Quote
Old   August 24, 2005, 03:16
Default Does rho vary with time?
Old   August 24, 2005, 03:38
Default Yes, rho varies with time.
Sang Yong Lee
Old   August 24, 2005, 03:46
Default In that case they are clearly
In that case they are clearly different, the first is the rate of change of rho*e and the second is rho* the rate of change of e, wasn't that obvious?
Old   August 24, 2005, 04:13
Default Yes, it is obvious. Could you
Sang Yong Lee
Yes, it is obvious.
Could you tell me the correct expression among the following ones;
fvm::ddt(rho,e)=( (rho)^^(n+1)*e^^(n+1) - (rho)^^n*e^^n )/dt or
fvm::ddt(rho,e)=( (rho)^^n*e^^(n+1) - (rho)^^n*e^^n )/dt
Or, if both are not correct, give me correct one please .
Thank you
Old   August 24, 2005, 04:20
Default The first expression correspon
The first expression corresponds to an Euler-implicit discretisation of fvm::ddt(rho,e) and the second is clearly equivalent to an Euler-implicit discretisation of rho*fvm::ddt(e).
If you need to know these details you should look at the source code, it is all there ready and waiting for you, all you have to do is load it into an editor. The files you need to look at for implicit temporal discretisation are all in OpenFOAM-1.2/src/OpenFOAM/finiteVolume/ddtSchemes.
Old   September 21, 2005, 01:33
Default Dr. Weller I am trying to imp
Sang Yong Lee
Dr. Weller
I am trying to implement energy equation in bubbleFoam. I have problems with the disapprearing phases. As I reviewed your technical report, TR/HGW/02, Derivation...., I got an idea that your phase intensive momentum equation approach might help me. Could you give me some comments on using phase intensive energy equation instead of using the energy equation in conservative form.
Difference between bubblefoam and twophaseeulerfoam ebaerow OpenFOAM Running, Solving & CFD 3 March 14, 2009 06:55
KEpsilon in bubbleFoam and twoPhaseEulerFoam vkaufmann OpenFOAM Running, Solving & CFD 0 November 5, 2008 08:25
Lift force modeling in bubbleFoam holger_marschall OpenFOAM Running, Solving & CFD 2 December 10, 2007 15:24
CVMcoefficient in bubblefoam stephan OpenFOAM Running, Solving & CFD 4 December 19, 2006 01:48
Multiphase flow in bubbleFoam case brahim OpenFOAM Running, Solving & CFD 2 July 25, 2005 14:07
