August 17, 2005, 02:03 |
I am using simpleFoam with kEp
I am using simpleFoam with kEpsilon model. After few iterations it looks like it stops solving equations of k and epsilon as I don't see error on my terminal. Does this mean that these equations diverged? How to make it visible all the time. I have experimented with "tolerences" as well as "relaxation factors" no improvement.
Regards GS |
August 17, 2005, 02:07 |
Maybe the initial residual is
Xiaofeng Liu
Rep Power: 17 |
Maybe the initial residual is less than tolerences, so these equations don't need to be solved. Steady state?
Xiaofeng Liu, Ph.D., P.E., Assistant Professor Department of Civil and Environmental Engineering Penn State University 223B Sackett Building University Park, PA 16802 Web: http://water.engr.psu.edu/liu/ |
August 17, 2005, 02:10 |
Yes, steady state, I was guess
Yes, steady state, I was guessing the same, but I still want to solve. How do I do that.
Regards |
August 17, 2005, 04:30 |
Do you see the initial residua
Rep Power: 22 |
Do you see the initial residual fall? Does it drop below your convergence tolerance? Have you tried making the convergence tolerance very tight?
August 17, 2005, 04:40 |
Yes, initially there is reduction in residual. >Does it drop below your convergence tolerance? Yes >Have you tried making the convergence tolerance very tight? Yes Currently I am compiling the code by making following change in "tests.C" //converged_ = true; converged_ = false; Will this help? Regards GS |
August 17, 2005, 04:53 |
I would be able to help you mo
Rep Power: 22 |
I would be able to help you more if I had the answers to my questions or better still a section of the log file from just before k-epsilon stop solving to just after.
August 17, 2005, 04:55 |
Sorry, I missed the answers bu
Rep Power: 22 |
Sorry, I missed the answers buried there. Anyway, I would still like to see the section of log file. Have you looked the the field valeus for k-epsilon? Are they VERY large?
August 17, 2005, 07:18 |
BICCG: Solving for Ux, Initia
BICCG: Solving for Ux, Initial residual = 0.0114222, Final residual = 0.000931753, No Iterations 1
BICCG: Solving for Uy, Initial residual = 0.0227955, Final residual = 0.00190204, No Iterations 1 BICCG: Solving for Uz, Initial residual = 0.00691902, Final residual = 0.000593082, No Iterations 1 ICCG: Solving for p, Initial residual = 0.0216008, Final residual = 0.000214944, No Iterations 116 time step continuity errors : sum local = 0.00871451, global = 0.000437168, cumulative = 0.0171293 BICCG: Solving for epsilon, Initial residual = 0.021943, Final residual = 2.2619e-08, No Iterations 1 BICCG: Solving for k, Initial residual = 1.78372e-05, Final residual = 1.1457e-06, No Iterations 1 ExecutionTime = 201 s Time = 257 BICCG: Solving for Ux, Initial residual = 0.0114393, Final residual = 0.000938528, No Iterations 1 BICCG: Solving for Uy, Initial residual = 0.0228175, Final residual = 0.0019204, No Iterations 1 BICCG: Solving for Uz, Initial residual = 0.00691351, Final residual = 0.00059707, No Iterations 1 ICCG: Solving for p, Initial residual = 0.0229688, Final residual = 0.000222948, No Iterations 115 time step continuity errors : sum local = 0.00902571, global = 0.000449829, cumulative = 0.0175791 BICCG: Solving for epsilon, Initial residual = 0.0225105, Final residual = 2.18334e-08, No Iterations 1 bounding epsilon, min: -3.5104e-12 max: 822122 average: 4651.92 ExecutionTime = 205.23 s Time = 258 BICCG: Solving for Ux, Initial residual = 0.0114469, Final residual = 0.00095594, No Iterations 1 BICCG: Solving for Uy, Initial residual = 0.0226974, Final residual = 0.00194632, No Iterations 1 BICCG: Solving for Uz, Initial residual = 0.00688176, Final residual = 0.000596608, No Iterations 1 ICCG: Solving for p, Initial residual = 0.0220571, Final residual = 0.00021926, No Iterations 118 time step continuity errors : sum local = 0.00883914, global = 0.000396233, cumulative = 0.0179754 Will this help to clarify myself? You can see after Time(iteration) # 257, k and epsilon disappears forever. Regards GS |
August 17, 2005, 07:27 |
What convergence tolerance hav
#9 |
Rep Power: 22 |
What convergence tolerance have you set for k and epsilon?
August 17, 2005, 07:31 |
For both 1e-5(Tolerance), 0.1(
#10 |
For both 1e-5(Tolerance), 0.1(RelativeTolerance)
August 17, 2005, 07:35 |
For cases will wall-functions
#11 |
Rep Power: 22 |
For cases will wall-functions I use 1e-8.
August 17, 2005, 07:38 |
Now I am running with 1e-15 an
#12 |
Now I am running with 1e-15 and 0.1 for both. It appears again. This way what is the lower tolerence limit?
Thanks and regards GS |
August 17, 2005, 07:43 |
Check the k and epsilon fields
#13 |
Rep Power: 22 |
Check the k and epsilon fields, it sounds like they are becoming VERY large which affecting the residual normalisation.
August 17, 2005, 08:03 |
Max epsilon is 676404.2 m^2/s^
#14 |
Max epsilon is 676404.2 m^2/s^3 and k is 72 m^/s^2, which is not too large value.
It has disappeared again even after giving tolerance 1e-15 for both k and epsilon. Regards GS |
August 17, 2005, 08:08 |
It appears k and epsilon have
#15 |
Rep Power: 22 |
It appears k and epsilon have converged for your case.
August 17, 2005, 08:12 |
But I do not want it to stop s
#16 |
But I do not want it to stop solving k and epsilon, as flow field is still developing. How do I do that?
Regards GS |
August 17, 2005, 08:19 |
For some reason, probably due
#17 |
Rep Power: 22 |
For some reason, probably due to something in your setup/BCs, the k-epsilon system has converged and nothing you do to the tolerances will make it converge further. You need to find out what is wrong with your setup.
We would be happy to check and correct your case as part of your support contract with OpenCFD. |
Error message-Floating point error | Vaibhav | FLUENT | 3 | December 7, 2007 05:38 |
ERROR MESSAGE: line 1: parse error | Lourival | FLUENT | 1 | February 18, 2006 01:35 |
help on error message | zwdi | FLUENT | 1 | January 10, 2004 22:58 |
Gambit 2.0 - Error Message (ACIS ERROR 1200) | James | FLUENT | 1 | May 14, 2003 08:13 |
VOF, Liquid disappears !! | Nik | FLUENT | 2 | November 24, 2002 01:13 |
