How to set a grid system of my own
Old   August 12, 2005, 07:10
Default i have use the example grid fo
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
i have use the example grid for compuation.
but i want to compute a problem of my own,
need i to write the whole dictionaly by hand?
regards
ztdep is offline   Reply With Quote
Old   August 12, 2005, 11:07
Default HI, ztdep, You have to modi
Pei-Ying Hsieh
hsieh is on a distinguished road
HI, ztdep,
You have to modify blockMeshDict to build your gemoetry and mesh it. Or, you can use netgen to generate Tet mesh of your model (it reads stl/step/igs files).
pei
hsieh is offline   Reply With Quote
Old   August 12, 2005, 23:13
Default but i was a very complex gemoe
ztdep's Avatar
p ding
but i was a very complex gemoetry ,
it was a heat exchanger.
what should i do .
Old   August 12, 2005, 23:25
Default Hello ztdep, you can generate
Alberto Passalacqua
Hello ztdep,
you can generate the grid in a CAD/Mesh genearation tool. You can convert from the formats reported here: http://www.opencfd.co.uk/openfoam/do...l#x15-920003.6
Regards,
Alberto
Alberto Passalacqua
Old   August 15, 2005, 00:54
Default i use the gridgen to generate
ztdep's Avatar
p ding
i use the gridgen to generate my grid system,
what should i do next step!
regards!
Old   August 15, 2005, 11:02
Default HI, ztdep, Save the mesh/BC
Pei-Ying Hsieh
HI, ztdep,
Save the mesh/BCs to Fluent/CFX/Star-CD format. Then use OpenFOAM conversion utility (check user manual) to convert it to OpenFOAM format. then, you can run the solver.
pei
Old   August 16, 2005, 21:55
Default is it nessaray to save the BC
ztdep's Avatar
p ding
is it nessaray to save the BC for Fluent,
regards
Old   August 16, 2005, 22:21
Default Yes, in GAMBIT, set the bounda
Alberto Passalacqua
Yes, in GAMBIT, set the boundary conditions.
However, when imported in OpenFOAM, you'll have to set them again. The converter keeps the BC's names, but not their type.
Regards,
Alberto
Alberto Passalacqua
file reread-grid (reading new grid w/o wiping out John McKelliget FLUENT 4 January 11, 2007 03:32
FOAM use a staggerd grid or collocated grid system ztdep OpenFOAM Running, Solving & CFD 0 September 15, 2005 11:53
About the moving grid system paul Main CFD Forum 0 October 25, 2004 00:47
How to generate grid system with a curved surface Jing Ren Siemens 3 March 13, 2001 11:58
