Turbulent compressible and subsonic gas flow
Old   December 15, 2004, 10:47
Default I have a simple question for
Rasmus Gjesing (Gjesing)
I have a simple question for the board.
Which solver applies best for a turbulent, compressible and subsonic (0.4<M<1.0) flow?
I have tried setting up a calculation using sonicTurbFoam, inspired by the prism-tutorial, but when I go down in Machs, I find it hard to make succesful calculations.
Thanks in advance.
Old   December 16, 2004, 06:08
Default coodles the compressible LES
Eugene de Villiers (Eugene)
coodles the compressible LES solver works very well for unsteady 3D flows at all kinds of Mach numbers.
Old   December 16, 2004, 07:51
Default coodles, is that a new solver
coodles, is that a new solver included in the new openFoam-version? I am currently using foam2.3 from the old days.
Thanks for the help!
Old   December 16, 2004, 09:04
Default Yes.
Yes.
Old   December 16, 2004, 11:35
Default I have now succesfully update
I have now succesfully updated my computers to OpenFOAM-1.0.
I have found the coodles-solver, but I cannot find the configuration files for FoamX.
Would it be possible to get the FoamX configuration-files for coodles from you guys, in case you have them?
Thanks again for all your help!
Old   December 16, 2004, 11:42
Default Guess that one hasn't been do
Mattijs Janssens (Mattijs)
Guess that one hasn't been done yet. Probably it takes the same setup (apart from boundary conditions) as oodles. Have a look at the oodles tutorial.
Mattijs
Old   December 20, 2004, 13:34
Default But what should I do, if I on
Joern Beilke (Beilke)
But what should I do, if I only want a normal turbulence model together with an incompressible flow (Ma < 0.5) (like starcd with ideal gas)?
Old   December 20, 2004, 13:45
Default turbFoam = incompressible + t
turbFoam = incompressible + turbulence model.
Mattijs
Old   December 20, 2004, 15:11
Default Sorry, I mean compressible wi
Sorry, I mean compressible with standard KEpsilon ;-)
Old   December 21, 2004, 17:36
Default We have not written a basic c
Henry Weller (Henry)
We have not written a basic compressible turbulent flow solver because it has not been needed although this functinality does form the basis of all the combustion codes. If you take XiFoam for example and strip out all the combustion modelling you will end up with a basic compressible turbulent flow solver which should suit your needs. If you would like OpenCFD write one for you let us know and we can discuss a small contract to cover this application development and associated documentation and FoamX preprocessor support.
Old   March 16, 2005, 20:01
Default I am using rhoTurbFoam for an
  #11
Jarrod Sinclair
sinclair is on a distinguished road
I am using rhoTurbFoam for an exhaust manifold simulation on a high quality hex mesh. It appears to be running fine with Co<=0.3. Initialisation is from a reasonably converged simpleFoam simulation (with no problems of turbulence bounding). I've made some modifications to achieve an adaptive number of piso and non-orthogonal corrections at each timestep (I can share these modifications if people are interested).
I have some problems though that people may have some experience with:
1) After quite some time of steady timestep advancement, the enthalpy correction blows up and gives the following error...
BICCG: Solving for h, Initial residual = 0.00719075, Final residual = 2.63587e-05, No Iterations 1
--> FOAM FATAL ERROR : Maximum number of iterations exceeded
Function: specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const
in file: /home/dm2/henry/OpenFOAM/OpenFOAM-1.1/src/thermophysicalModels/specie/lnInclude/ specieThermoI.H at line: 83.
Although, it appears that the enthalpy equation has converged (shown above). The error is caused when it is exceeding the 100 iterations to obtain a temperature value. This problem persists even when turbulence is switched off.
2) Like with enthalpy, sometimes the k and epsilon fields need to be bounded after some time of well behaved timesteps (~1000 timesteps).
bounding epsilon, min: -5.3484e+07 max: 5.80694e+10 average: 3.62477e+06
I am using the Gamma2 scheme for k and epsilon convection with a value of 1. Does anyone have any tips with this?
sinclair is offline   Reply With Quote
Old   March 17, 2005, 03:11
Default Not sure about 1 but I can tel
  #12
Hrvoje Jasak
Not sure about 1 but I can tell you about 2.
The problem with bounding means that your setup of differencing schemes may be problematic. The convection differencing is OK, even a bit too conservative - you should not need to use the factor greater than about 0.5.
The problem may be in the laplacian - could you please try to run checkMesh and tell me what the non-orthogonality angles are. If they are big-ish, try the laplacian scheme like this (for k and epsilon, and maybe for the enthalpy as well)
laplacian(thingy,thingy) Gauss linear limited 0.5;
This is interesting, please keep me posted (you can fiddle the last number, 0.7 or 1 should work as well),
Hrv
Hrvoje Jasak
Old   March 17, 2005, 07:56
Default Hi Hrvoje, I am currently r
  #13
Jarrod Sinclair
Hi Hrvoje,
I am currently running a kEpsilon case with the changes to the laplacian scheme you suggest (k, epsilon and enthalpy). Will let you know of the result.
As for the checkMesh non-orthogonality angles, some key measures are...
Mesh non-orthogonality Max: 52.5196 average: 11.7172
Non-orthogonality check OK.
Max skewness = 27.6894 percent. Face skewness OK.
Minumum edge length = 0.000309256. Maximum edge length = 0.00480689.
All angles in faces are convex or less than 10 degrees concave.
Number of cells by type:
hexahedra: 169024
Mesh OK.
...etc...
Old   March 18, 2005, 01:49
Default Hrvoje, I have tried differ
  #14
Jarrod Sinclair
Hrvoje,
I have tried different variants of limited (0.333, 0.5, 0.7), corrected and uncorrected on the k, epsilon and enthalpy Laplacians. Bounding on both k and epsilon still occurs at various stages, then crashes due to enthalpy (temperature) exceeding maximum number of iterations.
Old   March 18, 2005, 02:41
Default Hmm, I was afraid of that when
  #15
Hrvoje Jasak
Hmm, I was afraid of that when I saw the max non-orthogonality angle - this really is a good mesh.
Sorry to waste your time, but I've got a couple more ideas to try:
- if you are using partial convergence in the solver, try converging all the way
- the final thing I do in such cases is to switch the convection discretisation to upwind. If there are still problems with bounding k and epsilon, this would indicate serious problems with the solver (or a nasty bug).
If all that fails (this is now pretty conservative discretisation and foam is certainly able of doing better) and the geometry is not confidential (and below a million cells), I'd like to have a look at it.
Sorry for the trouble, I am running out of easy ideas. Please let me know.
Regards,
Hrv
Hrvoje Jasak
Old   March 18, 2005, 03:40
Default Jarrod, There may be some i
  #16
henry is on a distinguished road
Jarrod,
There may be some issues with the JANAF thermodynamics/heat-transfer due to some developments I made to the thermo library to handle complex boundary conditions. I am not sure if these problems might relate to your case failing but you could try using constant coefficient termodynamics and/or adiabatic walls.
henry is offline   Reply With Quote
Old   April 21, 2005, 07:11
Default I have the same problems as Ja
  #17
Daniele Panara
panara is on a distinguished road
I have the same problems as Jarrod,
I am trying to simulate a channel flow with constant wall heat flux.
I cannot use adiabatic walls so what should I do?
Should I use another solver?
Daniele
panara is offline   Reply With Quote
Old   April 21, 2005, 07:15
Default Constant wall heat flux is eqi
  #18
Constant wall heat flux is eqivalent to a fixed gradient boundary condition on energy/temperature.
Old   April 21, 2005, 07:19
Default Yes, I am using fixed gradient
  #19
Daniele Panara
Yes, I am using fixed gradient boundary condition on temperature and I get the same error message as Jarrod.
It is related to the boundary condition I am giving or something else?
Old   April 21, 2005, 07:26
Default What OpenFOAM version are you
  #20
What OpenFOAM version are you running?
What solver?
What thermodynamics package?
Have you tried changing the gradient?
Does it run if the gradient is small enough?
Have you tried changing the sign of the gradient?
Compressible turbulent flow FVS Main CFD Forum 1 June 14, 2017 11:45
Compressible Turbulent Flow CFDtoy Main CFD Forum 5 January 19, 2005 04:41
bench mark for subsonic compressible turbulent fl javadi Main CFD Forum 0 June 14, 2004 08:40
need tubulence compressible subsonic benchmark javadi Main CFD Forum 1 June 14, 2004 08:36
compressible subsonic flow Joel Siemens 2 April 24, 2003 08:18
