DieselFoam error turbulent dispersion
Old   April 22, 2005, 04:48
Default Hi, When I activate turbule
Ervin Adorean
adorean is on a distinguished road
When I activate turbulent dispersion in an axisymmetric diesel spray simulation, get this error:
Create time
Create mesh for time = 0
Reading thermophysicalProperties
Selecting thermodynamics package hMixtureThermo<reactingmixture>
Selecting chemistryReader chemkinReader
Reading field U
Creating turbulence model.
Selecting turbulence model RNGkEpsilon
Creating field DpDt
Constructing chemical mechanism
Selecting ODE solver SIBS
chemistryModel::chemistryModel: Number of species = 5 and reactions = 1
Reading environmentalProperties
Reading combustion properties
Constructing Spray
Selecting injectorType commonRailInjector
Selecting atomizationModel off
Selecting dragModel standardDragModel
Selecting evaporationModel standardEvaporationModel
Selecting heatTransferModel RanzMarshall
Selecting wallModel reflect
Selecting breakupModel ReitzKHRT
Selecting collisionModel trajectory
Selecting dispersionModel gradientDispersionRAS
--> FOAM FATAL ERROR :
request for turbulenceModel turbulenceProperties from objectRegistry failed
available objects of type turbulenceModel are
0
Function: objectRegistry::lookupObject<type>(const word&) const
in file: /home/ervin/OpenFOAM/OpenFOAM-1.1/src/OpenFOAM/lnInclude/objectRegistryTemplates .C at line: 122.
FOAM aborting
Can somebody tell me what is this about, and how can this be corrected?
Thanks.
Ervin
adorean is offline   Reply With Quote
Old   April 22, 2005, 05:03
Default looks like we forgot to change
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
looks like we forgot to change this with the new change in runTime/mesh, Henry?
in dispersionRASModel.C change the line
sm.runTime().lookupObject<compressible::turbulence model>
to
sm.mesh().lookupObject<compressible::turbulencemod el>
and 'wmake libso' in the dieselSpray-dir.
worked for me
N
niklas is offline   Reply With Quote
Old   April 22, 2005, 05:16
Default Worked for me too. Thanks,
Ervin Adorean
Worked for me too.
Thanks, Niklas.
Ervin
Old   April 22, 2005, 05:27
Default Well, now I've got myself a di
Ervin Adorean
Well, now I've got myself a different error message:
Time = 0.000585
Evolving Spray
Solving chemistry
BICCG: Solving for Ux, Initial residual = 0.0893508, Final residual = 3.71189e-08, No Iterations 4
BICCG: Solving for Uy, Initial residual = 0.0470008, Final residual = 8.18107e-07, No Iterations 3
BICCG: Solving for Uz, Initial residual = 0.00210555, Final residual = 4.94314e-08, No Iterations 3
BICCG: Solving for C7H16, Initial residual = 0.00283565, Final residual = 2.4395e-07, No Iterations 2
BICCG: Solving for O2, Initial residual = 0.00264662, Final residual = 8.18177e-07, No Iterations 2
BICCG: Solving for CO2, Initial residual = 0.00283727, Final residual = 2.09632e-07, No Iterations 2
BICCG: Solving for H2O, Initial residual = 0.00283727, Final residual = 2.09632e-07, No Iterations 2
BICCG: Solving for h, Initial residual = 0.00291149, Final residual = 3.13086e-07, No Iterations 2
ICCG: Solving for p, Initial residual = 0.62558, Final residual = 6.53001e-10, No Iterations 28
time step continuity errors : sum local = 3.69438e-12, global = -4.5675e-13, cumulative = -4.31118e-11
ICCG: Solving for p, Initial residual = 0.121549, Final residual = 5.99677e-10, No Iterations 27
time step continuity errors : sum local = 4.06811e-12, global = -8.22919e-13, cumulative = -4.39347e-11
BICCG: Solving for epsilon, Initial residual = 0.00106245, Final residual = 6.1007e-07, No Iterations 2
bounding epsilon, min: -1.59758e+11 max: 9.5401e+11 average: 2.79012e+08
BICCG: Solving for k, Initial residual = 0.4897, Final residual = 4.5726e-07, No Iterations 2
Number of parcels in system | 1101
Injected liquid mass....... | 3.26959 mg
Liquid Mass in system...... | 1.13211 mg
SMD, Dmax.................. | 13.5651 mu, 145.611 mu
Added gas mass = 2.13748 mg
Evaporation Continuity Error| 8.76679e-13 mg
ExecutionTime = 294.19 s
Max Courant Number = 2.12046
Time = 0.00059
Evolving Spray
Solving chemistry
BICCG: Solving for Ux, Initial residual = 0.0458617, Final residual = 9.53264e-07, No Iterations 3
BICCG: Solving for Uy, Initial residual = 0.158556, Final residual = 6.22212e-07, No Iterations 4
BICCG: Solving for Uz, Initial residual = 0.00461368, Final residual = 5.90762e-08, No Iterations 4
BICCG: Solving for C7H16, Initial residual = 0.00282151, Final residual = 2.05982e-07, No Iterations 3
BICCG: Solving for O2, Initial residual = 0.00261989, Final residual = 3.43801e-07, No Iterations 3
BICCG: Solving for CO2, Initial residual = 0.00304074, Final residual = 5.55743e-07, No Iterations 3
BICCG: Solving for H2O, Initial residual = 0.00304074, Final residual = 5.55743e-07, No Iterations 3
BICCG: Solving for h, Initial residual = 0.00385778, Final residual = 6.85247e-07, No Iterations 3
--> FOAM FATAL ERROR : attempt to use janafThermo<equationofstate> out of temperature range 200 -> 5000; T = 191.289
Function: janafThermo<equationofstate>::checkT(const scalar T) const
in file: /home/ervin/OpenFOAM/OpenFOAM-1.1/src/thermophysicalModels/specie/lnInclude/jana fThermoI.H at line: 73.
FOAM aborting
How can this error be corrected/prevented?
Ervin
Old   April 22, 2005, 06:02
Default Hi Niklas, Yes this is a bu
henry is on a distinguished road
Hi Niklas,
Yes this is a bug in 1.1, you also need to make the eqivalent change in dispersionLESModel.C:
sm.runTime().lookupObject<compressible::lesmodel>
to
sm.mesh().lookupObject<compressible::lesmodel>
I have fixed this for 1.1.1
H
henry is offline   Reply With Quote
Old   April 22, 2005, 06:39
Default The above mentioned 'out of te
Ervin Adorean
The above mentioned 'out of temperature range' error happened because of an ill imposed wall temp. bc (I think). I've changed to fixedValue uniform 293 K and it worked.
Ervin
Old   April 22, 2005, 06:55
Default Hi, the 'out of temperature
niklas's Avatar
Niklas Nordin
the 'out of temperature range' is a secondary
effect of a 'crashed' run,
look at the courant number 2.1!!!
try keeping the courant number low.
The problem with spray calculations are that if you have large/sudden variation in injection velocity
the added momentum, or energy, can be substantial and you will get this kind of error.
N
Running dieselFoam error adorean OpenFOAM Running, Solving & CFD 119 February 1, 2016 14:41
DPM turbulent dispersion Springbok Main CFD Forum 0 July 15, 2008 04:14
Turbulent Dispersion in Particle Tracking ariel CFX 2 April 22, 2008 22:02
Turbulent dispersion Julie Polyakh Siemens 0 May 15, 2003 07:14
turbulent dispersion of particles! danney CFX 0 April 2, 2003 09:17
