Memory requirements of OF tools
Like Tree1Likes
  • 1 Post By wyldckat
Old   December 16, 2007, 07:53
Default Memory requirements of OF tools
BastiL
bastil is on a distinguished road
Hi group,
I would like to add some feedback from my experiences with OF tools in comparison to commercial tools concerning memory requirements:
I made a 45 Mio cells tetra mesh using STAR-CCM+ un a 16 GB Workstation and tried to convert it to FOAM using ccm26toFoam. This worked. However, checkMesh and polyDualMesh ran out of memory. Is there a rule of thumb for memory requirement for the OF tools?
BastiL
bastil is offline   Reply With Quote
Old   December 17, 2007, 03:43
Default It mainly depends on the appli
Francesco Del Citto
fra76 is on a distinguished road
It mainly depends on the application...
I noticed that, for example, renumberMesh takes much more memory than checkMesh.
In any case you can reduce the memory requirements by using single precision tools, in case you run out of memory.
Francesco
fra76 is offline   Reply With Quote
Old   December 17, 2007, 15:02
Default checkMesh constructs all possi
Mattijs Janssens
checkMesh constructs all possible addressing (have a look at primitiveMesh) which is very expensive. Most solvers (and probably ccm26ToFoam) will only use a small subset of addressing (no edge or point addressing) so are much cheaper.
Old   March 26, 2014, 08:35
Default polyDualMesh-Memoryrequest
Tobias Adam
Tobias Adam is on a distinguished road
Hello everyone,
really old thread, but I think it fits to the topic :-)
I made a funny experience with the memory requirement of polyDualMesh.
When I ran this utility without any options chosen like e.g. -overwrite it ran out of memory.
But when I use the option doNotPreserveFaceZones it works!
Best reagards
Tobias Adam is offline   Reply With Quote
Old   April 22, 2016, 14:26
Peng Liang
tjliang is on a distinguished road
Francesco
Could you please tell me how to determine the memory usage of opfenfoam? Thanks.
Best regards,
Peng
_______________
Dear all,
I am writing an application for a cluster usage permition. In the application i need to declare how much memory i need for openfoam parallel simulation. Could someone tell me how to check Openfoam memory usage when running parallel simulations, thanks in advance.
Best Regards,
Peng
Last edited by wyldckat; May 1, 2016 at 17:17. Reason: merged posts that were a few minutes apart
tjliang is offline   Reply With Quote
Old   May 1, 2016, 17:19
Retired Super Moderator
Bruno Santos
Quick answer: My rule of thumb is that it requires roughly 1GB per 1 million cells.
You should do some tests with OpenFOAM tutorials that are similar to the case you are using and check how much RAM each application or solver needs in your cases, because the RAM needed varies with the solver and the type of mesh.
JorgeSS likes this.
memory request, polydualmesh
Memory requirements for serial and parallel runs denner OpenFOAM Running, Solving & CFD 0 August 26, 2008 15:11
memory requirements - beowulf cluster mary FLUENT 3 November 20, 2004 08:53
CFX-5.7 - Serial PC Maximum Memory Requirements James Date CFX 15 November 16, 2004 11:05
memory requirements Novak Elliott CFX 3 June 6, 2003 02:50
