March 17, 2009, 05:44 |
Outlet condition for open channel flow?
Gareth
Hi
I'm modelling a river with an obstruction in the middle. It's modelled as a simple rectangular channel, using rasInterFoam, OF 1.5. The inlet is split into two, one of which is the water inlet (v=1m/s) and the upper part is air (0m/s). I set gamma at 1 and 0 respectivly on these inlets, then setFields to set the intitial free surface throughout the domain. A quick look in paraview shows it's all ok at t=0. At the moment there is just one outlet patch, as I don't know where the phase interface will be (slightly lower than that at the inlet I hope!) I have set it as fixedValue pressure, and zeroGradient velocity on this outlet patch, but it produces some very strange results with some problems around the interface (maybe from the compression term applied to the VOF model?) Is there a more suitable outlet boundary condition? Or is this a more fundamental problem which will require deeper coding? I'm a complete beginner here... Thank you Gareth |
July 17, 2011, 03:44 |
Mark Beal
Hi Gareth,
Did you find a solution to this? I'm also interested in the correct inlet/outlet boundary conditions for a channel flow using interFoam. Mark |
Boundary condition problem for open channel flow | Andy | CFX | 9 | June 11, 2016 07:20 |
pressure outlet (open channel flow) | Willem Brantegem | FLUENT | 2 | April 4, 2007 02:40 |
pressure outlet (open channel flow) | Willem Brantegem | Main CFD Forum | 0 | April 3, 2007 09:39 |
Outlet boundary condition in channel flow solving with interFoam | liuzhw | OpenFOAM Running, Solving & CFD | 0 | November 29, 2005 21:07 |
open channel flow | Frank | Main CFD Forum | 3 | December 15, 2000 03:32 |
