buoyantSimpleFoam crashes only when BC for velocity at inlet exceeds a certain value |
June 14, 2020, 17:12 |
Rep Power: 6 |
Dear Foamers,
I have got a problem using buoyantSimpleFoam for a heat transfer case. Whenever I use a velocity boundary condition for the two inlets higher than a certain value (the maximum value that works is 13.2) I get the following error code at fourth time step: Code:
Starting time loop Time = 1 DILUPBiCGStab: Solving for h, Initial residual = 1, Final residual = 0.00170966, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 0.00557072, No Iterations 7 time step continuity errors : sum local = 0.10991, global = 0.00504564, cumulative = 0.00504564 rho max/min : 1.17397 1.00626 DILUPBiCGStab: Solving for omega, Initial residual = 0.00769473, Final residual = 3.32288e-06, No Iterations 1 DILUPBiCGStab: Solving for k, Initial residual = 1, Final residual = 0.00646544, No Iterations 1 ExecutionTime = 12.99 s ClockTime = 14 s Time = 2 DILUPBiCGStab: Solving for h, Initial residual = 0.707512, Final residual = 0.00134701, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.0188145, Final residual = 0.000139613, No Iterations 4 time step continuity errors : sum local = 10.5002, global = -0.508423, cumulative = -0.503377 rho max/min : 5.68128 1.03367 DILUPBiCGStab: Solving for omega, Initial residual = 0.029101, Final residual = 7.18413e-06, No Iterations 1 DILUPBiCGStab: Solving for k, Initial residual = 0.960528, Final residual = 0.00728786, No Iterations 1 ExecutionTime = 18.35 s ClockTime = 19 s Time = 3 DILUPBiCGStab: Solving for h, Initial residual = 0.638894, Final residual = 0.0021587, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.011095, Final residual = 9.57394e-05, No Iterations 4 time step continuity errors : sum local = 6.01821, global = 1.52077, cumulative = 1.01739 rho max/min : 3.06482 0.945442 DILUPBiCGStab: Solving for omega, Initial residual = 0.0956394, Final residual = 0.00013444, No Iterations 1 bounding omega, min: -59.9638 max: 30099.9 average: 71.9794 DILUPBiCGStab: Solving for k, Initial residual = 0.205061, Final residual = 0.000447495, No Iterations 1 ExecutionTime = 23.77 s ClockTime = 25 s Time = 4 DILUPBiCGStab: Solving for h, Initial residual = 0.197362, Final residual = 0.000685917, No Iterations 1 [0] [1] #0 Foam::error::printStack(Foam::Ostream&)[2] #0 Foam::error::printStack(Foam::Ostream&)#0 Foam::error::printStack(Foam::Ostream&) at ??:? [2] #1 Foam::sigFpe::sigHandler(int) at ??:? [1] #1 Foam::sigFpe::sigHandler(int) at ??:? [0] #1 Foam::sigFpe::sigHandler(int) at ??:? [2] #2 ? at ??:? [0] #2 ? at ??:? [1] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [0] #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/lib/x86_64-linux-gnu/libc.so.6" [2] #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/lib/x86_64-linux-gnu/libc.so.6" [1] #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? [2] #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? [0] #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? [1] #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? [0] #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? [2] #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? [1] #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? [2] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? [0] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? [1] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? [0] #7 at ??:? [2] #7 at ??:? [1] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&)Foam::fvMatrix<double>::solve(Foam::dictionary const&)Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/buoyantSimpleFoam" [0] #8 in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/buoyantSimpleFoam" [2] #8 in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/buoyantSimpleFoam" [1] #8 Foam::fvMatrix<double>::solve()Foam::fvMatrix<double>::solve()Foam::fvMatrix<double>::solve() in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/buoyantSimpleFoam" [0] #9 in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/buoyantSimpleFoam" [2] #9 in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/buoyantSimpleFoam" [1] #9 ??? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/buoyantSimpleFoam" [0] #10 __libc_start_main in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/buoyantSimpleFoam" [2] #10 __libc_start_main in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/buoyantSimpleFoam" [1] #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [0] #11 in "/lib/x86_64-linux-gnu/libc.so.6" [2] #11 in "/lib/x86_64-linux-gnu/libc.so.6" [1] #11 ???[lars-B450M-DS3H:20606] *** Process received signal *** in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/buoyantSimpleFoam" [lars-B450M-DS3H:20606] Signal: Floating point exception (8) [lars-B450M-DS3H:20606] Signal code: (-6) [lars-B450M-DS3H:20606] Failing at address: 0x3e80000507e [lars-B450M-DS3H:20606] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f43a4531f20] [lars-B450M-DS3H:20606] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f43a4531e97] [lars-B450M-DS3H:20606] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f43a4531f20] [lars-B450M-DS3H:20606] [ 3] /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5scaleERNS_5FieldIdEES3_RKNS_9lduMatrixERKNS_10FieldFieldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKS2_h+0xae)[0x7f43a593c5be] [lars-B450M-DS3H:20606] [ 4] /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_S9_S9_RNS1_IS8_EESD_h+0x90a)[0x7f43a593feda] [lars-B450M-DS3H:20606] [ 5] /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x4af)[0x7f43a594232f] [lars-B450M-DS3H:20606] [ 6] /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x17d)[0x7f43a9804ced] [lars-B450M-DS3H:20606] [ 7] buoyantSimpleFoam(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x15b)[0x56486602f70b] [lars-B450M-DS3H:20606] [ 8] buoyantSimpleFoam(_ZN4Foam8fvMatrixIdE5solveEv+0x117)[0x56486602fa97] [lars-B450M-DS3H:20606] [ 9] buoyantSimpleFoam(+0x33f8a)[0x564865fdcf8a] [lars-B450M-DS3H:20606] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f43a4514b97] [lars-B450M-DS3H:20606] [11] buoyantSimpleFoam(+0x36e7a)[0x564865fdfe7a] [lars-B450M-DS3H:20606] *** End of error message *** in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/buoyantSimpleFoam" [lars-B450M-DS3H:20608] *** Process received signal *** [lars-B450M-DS3H:20608] Signal: Floating point exception (8) [lars-B450M-DS3H:20608] Signal code: (-6) [lars-B450M-DS3H:20608] Failing at address: 0x3e800005080 [lars-B450M-DS3H:20608] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f602c8a3f20] [lars-B450M-DS3H:20608] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f602c8a3e97] [lars-B450M-DS3H:20608] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f602c8a3f20] [lars-B450M-DS3H:20608] [ 3] /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5scaleERNS_5FieldIdEES3_RKNS_9lduMatrixERKNS_10FieldFieldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKS2_h+0xae)[0x7f602dcae5be] [lars-B450M-DS3H:20608] [ 4] /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_S9_S9_RNS1_IS8_EESD_h+0x90a)[0x7f602dcb1eda] [lars-B450M-DS3H:20608] [ 5] /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x4af)[0x7f602dcb432f] [lars-B450M-DS3H:20608] [ 6] /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x17d)[0x7f6031b76ced] [lars-B450M-DS3H:20608] [ 7] buoyantSimpleFoam(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x15b)[0x5556ea2e970b] [lars-B450M-DS3H:20608] [ 8] buoyantSimpleFoam(_ZN4Foam8fvMatrixIdE5solveEv+0x117)[0x5556ea2e9a97] [lars-B450M-DS3H:20608] [ 9] buoyantSimpleFoam(+0x33f8a)[0x5556ea296f8a] [lars-B450M-DS3H:20608] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f602c886b97] [lars-B450M-DS3H:20608] [11] buoyantSimpleFoam(+0x36e7a)[0x5556ea299e7a] [lars-B450M-DS3H:20608] *** End of error message *** in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/buoyantSimpleFoam" [lars-B450M-DS3H:20607] *** Process received signal *** [lars-B450M-DS3H:20607] Signal: Floating point exception (8) [lars-B450M-DS3H:20607] Signal code: (-6) [lars-B450M-DS3H:20607] Failing at address: 0x3e80000507f [lars-B450M-DS3H:20607] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f9525c34f20] [lars-B450M-DS3H:20607] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f9525c34e97] [lars-B450M-DS3H:20607] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f9525c34f20] [lars-B450M-DS3H:20607] [ 3] /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5scaleERNS_5FieldIdEES3_RKNS_9lduMatrixERKNS_10FieldFieldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKS2_h+0xae)[0x7f952703f5be] [lars-B450M-DS3H:20607] [ 4] /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_S9_S9_RNS1_IS8_EESD_h+0x90a)[0x7f9527042eda] [lars-B450M-DS3H:20607] [ 5] /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x4af)[0x7f952704532f] [lars-B450M-DS3H:20607] [ 6] /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x17d)[0x7f952af07ced] [lars-B450M-DS3H:20607] [ 7] buoyantSimpleFoam(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x15b)[0x55ec2854a70b] [lars-B450M-DS3H:20607] [ 8] buoyantSimpleFoam(_ZN4Foam8fvMatrixIdE5solveEv+0x117)[0x55ec2854aa97] [lars-B450M-DS3H:20607] [ 9] buoyantSimpleFoam(+0x33f8a)[0x55ec284f7f8a] [lars-B450M-DS3H:20607] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f9525c17b97] [lars-B450M-DS3H:20607] [11] buoyantSimpleFoam(+0x36e7a)[0x55ec284fae7a] [lars-B450M-DS3H:20607] *** End of error message *** Does anyone have any idea why the simulation crashes with buoyantSImpleFoam at higher velocities? Is there something wrong with the boundary conditions? Please find the case attached in case you want to try it on your own pc. I would be very happy if anyone could help me since I have been struggling with this problem for a long time now! Best regards, Lorg |
June 15, 2020, 04:18 |
Rep Power: 6 |
If it helps there is a table of all boundary conditions on one glance for the better overview attached.
Cheers! |
setting the correct format of nonuniform List<vector> for inlet in 0 Folder | cfdonline2mohsen | OpenFOAM Running, Solving & CFD | 8 | July 18, 2019 08:03 |
[waves2Foam] relaxationZone inlet | CFD-Henning | OpenFOAM Community Contributions | 2 | June 5, 2018 07:40 |
K-Omega-Epsilon BCs for suction inlet | CFDBro | OpenFOAM Running, Solving & CFD | 0 | March 27, 2018 18:28 |
velocity inlet and ideal gas simultaneously-what's wrong? | preetam69 | FLUENT | 0 | September 28, 2013 04:51 |
Inlet diffuser of ramjet | Mohammad Kermani | Main CFD Forum | 25 | December 29, 2000 18:46 |
