June 10, 2009, 14:45 |
Modifying the laplacian operator
Michael Lawson
Rep Power: 17 |
Hi everyone,
I would like to modify the laplacian so the derivative is only calculated in one direction - that is I would like to compute only d^2T/dx^2 and not d^2T/dx^2 + d^2T/dy^2 + d^2T/dz^2 Then I want to solve a system of equations using this modified laplacian. I tried to do this by dotting the result of the laplacian operator with a unit normal vector in the x-direction. A simple example would be: solve ( fvm::ddt(T) - fvm::laplacian(DT, T) & xDir // where xDir is a dimentionedVector with the units [0 1 -1 0 0 0 0] (1 0 0) ); Unfortunately, I get the following error when trying to compile my solver. --------------------------------------- 1dScalarTransportFoam.C: In function ‘int main(int, char**)’: 1dScalarTransportFoam.C:67: error: no match for ‘operator&’ in ‘Foam:perator-(const Foam::tmp<Foam::fvMatrix<Type> >&, const Foam::tmp<Foam::fvMatrix<Type> >&) [with Type = double](((const Foam::tmp<Foam::fvMatrix<double> >&)((const Foam::tmp<Foam::fvMatrix<double> >*)(& Foam::fvm::laplacian(const Foam::dimensioned<Type2>&, Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = double, GType = double](((Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&)(& T))))))) & xDir’ --------------------------------------- I assume I get this error because the & operator is not defined for a fvScalarMatrix. Does anyone know a method modifying the laplacian operator so that the derivative is only calculated in one direction? -Mike |
August 3, 2011, 16:27 |
Mieszko Młody
Rep Power: 17 |
I am trying to do the same thing. Did you manage to do this ? Method you described is wrong, because laplacian(DT,T) is not a vector , but scalar: Txx + Tyy + Tzz, so you cant make dot product operation for scalar and vector... I did it in explicit way, but this not the best way... If you have some updates how to solve this problem, pleas let me know. best -ZM |
August 3, 2011, 16:54 |
Michael Lawson
Rep Power: 17 |
You are correct the result of the laplacian operator is a scalar in this case. What should have asked is, is there a way to dot the laplacian operator itself with a unit vector before it is applied to the variable T (i.e (d/dx^2 + d/dy^2 + d/dz^2) dot (1 0 0) * T).
Either way, I never did solve this problem in a robust way. I ended up tricking the solver into only computing diffusion in one direction by making my two dimensional domain very long in one of the non-empty directions, the y-dir in my case, so the d/dy^2 term was negligible with respect to the d/dx^2 term. I know this is not a good way to solve the problem, but it ended up working for the specific case I was working on. Good luck and please let me know if you find a solution to the problem. -Mike |
August 3, 2011, 17:23 |
Mieszko Młody
Rep Power: 17 |
in explicit way u can do this like that:
volVectorField gradT=fvc::grad(T); volScalarField gradTx = gradT & vector(1,0,0); volScalarField Tx = gradT.component(0); // T_x volVectorField gradT2 = fvc::grad(Tx); // (T_xx, T_xy) volScalarField Txx = gradT2.component(0); // T_xx |
August 4, 2011, 03:32 |
Anton Kidess
Rep Power: 30 |
Michael, it sounds like you want anisotropic diffusion - why not just pass a diffusion coefficient tensor to laplacian instead of a scalar? I don't think you need any modifications to the code to do that (but I haven't tried it myself).
August 4, 2011, 10:32 |
Michael Lawson
Rep Power: 17 |
Hi Anton,
Mathematically that makes sense, but I'm unsure how to convert the scalar field T into a tensor in OpenFOAM. Do you have an idean about how this would be done? -Mike |
August 4, 2011, 10:49 |
Anton Kidess
Rep Power: 30 |
T stays a scalar field, you only have to change the diffusion coefficient into a tensor (you wouldn't do anything else on pen and paper). Redefine DT from dimensionedScalar to dimensionedTensor (see e.g. http://www.foamcfd.org/Nabla/guides/...sGuidese5.html) and recompile.
August 4, 2011, 12:13 |
Mieszko Młody
Rep Power: 17 |
Hi Akidess,
Thanks for your suggestion. It works just as it should. Human being is learning all its life... To Mlawson: x - direction diffusion: DTe DTe [ 0 2 -1 0 0 0 0 ] (3e-02 0 0 0 0 0 0 0 0 ); x,y and - directions diffusion: DTe DTe [ 0 2 -1 0 0 0 0 ] (3e-02 0 0 0 3e-02 0 0 0 3e-02 ); Thanks again! |
September 7, 2011, 11:51 |
#9 |
Matthias Voß
Rep Power: 20 |
hey there.
could anybody please give me a hint on where to find some sort of documentation for a part of the FSI-solver (icoFSIFoam??) like mentioned above. i am espacially interessted in how the pde´s have been derived for the solid/stress part. e.g. fvm::laplacian (2*mu, + lambda, Usolid, "laplacian (DU,U)") what is that third part good for? I wasn´t able to get any doc. for a third part in laplacian(..). Is this some sort of comment?? Thanks in advance, neewbie |
September 7, 2011, 12:05 |
#10 |
Mieszko Młody
Rep Power: 17 |
Third part "laplacian(DU,U)" is just needed for fvScheme file, where laplacian(DU,U) is defined. Here it just says that variable DU = 2*mu + lambda.
ZMM |
September 7, 2011, 12:06 |
#11 |
Matthias Voß
Rep Power: 20 |
okay.
found it. i guess. it´s a label for that part of the eq. to hook it up with the schemes in fvSchemes. |
September 7, 2011, 12:30 |
#12 |
Mieszko Młody
Rep Power: 17 |
I think that all needed information you can find in the solver description:l
inear-elastic, small-strain deformation of a solid body, with optional thermal diffusion and thermal stresses. For example in solver solidDisplacementFoamfact there are only two PDE solved (I dont know where FSIsolver is): fvm::ddt(T) == fvm::laplacian(DT, T) and fvm::d2dt2(D) == fvm::laplacian(2*mu + lambda, D, "laplacian(DD,D)") + divSigmaExp first equation is just standart heat equation, second equation is just linear-elastic equation with optional thermat stress (+ divSigmaExp) influence (calculated by solving first equation). This are standart equations so they derivation can be easly found in basic PDE books, or online: http://en.wikipedia.org/wiki/Linear_elasticity ZMM if (thermalStress) |
May 19, 2017, 10:35 |
#13 |
Xinguang Wang
Rep Power: 11 |
I still confused after reading all the thread. I need to separate Txx, Tyy and Tzz as mentioned.
Is there anyone give some example to do it? Thanks a lot. |
May 19, 2017, 13:43 |
#14 |
Mieszko Młody
Rep Power: 17 |
Hi Xinguang,
What do you need exactly ? Can you explain it with more details ? best ZMM |
May 20, 2017, 08:00 |
#15 |
Xinguang Wang
Rep Power: 11 |
hi ZMM
I want to calculate the second derivatives of a scalar field such as Temperature separately. For example, d^2T/d^2x, d^2T/d^2y and d^2T/d^2z, and then these three terms sum up as d^2T/d^2x + d^2T/d^2y + d^2T/d^2z = laplacian(T). I need to use each term for the calculation. Many thanks for your reply. Jaosn |
May 20, 2017, 08:22 |
#16 |
Xinguang Wang
Rep Power: 11 |
I also tried to use grad(grad) to calculate d^2T/d^2x d^2T/d^2y d^2T/d^2z , but when I add up these three terms, it's not equal to laplacian(T)
May 20, 2017, 10:16 |
#17 |
Mieszko Młody
Rep Power: 17 |
Laplacian does not equal grad(grad),
the true statment is: it OF reads: Laplacian(T) = div(grad(T)) so you could: gradT = grad(T) gradT.component(1)=0 gradT.component(2)=0 T_xx = div(gradT) gradT = grad(T) gradT.component(0)=0 gradT.component(2)=0 T_yy = div(gradT) gradT = grad(T) gradT.component(0)=0 gradT.component(1)=0 T_zz = div(gradT) OR: you could do as it is explained above: and define the diffusivity coeff as a tensor: for x - direction diffusion only: DTx DTx [ 0 2 -1 0 0 0 0 ] (1 0 0 0 0 0 0 0 0 ); in the code: T_xx=fvc::Laplacian(DTx,T) for y - direction diffusion only: DTy DTy [ 0 2 -1 0 0 0 0 ] (0 0 0 1 0 0 0 0 0 ); in the code: T_yy=fvc::Laplacian(DTy,T) for z - direction diffusion only: DTz DTz [ 0 2 -1 0 0 0 0 ] (0 0 0 0 0 0 1 0 0 ); in the code: T_zz=fvc::Laplacian(DTz,T) |
May 21, 2017, 07:00 |
#18 |
Xinguang Wang
Rep Power: 11 |
In my code Ux is a scalar field denotes the streamwise flow velocity.
const volScalarField du2dy2=fvc::laplacian(Eiy,Ux); where Eiy is (0,0,0,0,1,0,0,0,0) const volVectorField gradUx=fvc::grad(Ux); const volScalarField dudy=gradUx.component(vector::Y); const volVectorField graddudy=fvc::grad(dudy); const volScalarField divgradUx=fvc::div(gradUx); (for 2D flat plate flow dudx is very small) when I compare: term1= du2dy2 term2=graddudy.component(vector::Y) term3=divgradUx term2=term3(nearly the same), but term1 is not equal to term2 or term3 (30% less) In fvSchemes, the default scheme are all Gauss linear. Do I miss something to make such difference happens? |
May 21, 2017, 08:15 |
#19 |
Mieszko Młody
Rep Power: 17 |
in your case :
term3 = Ux_xx + Uy_yy + Ux_yz, so it wont be same as term1, to have ti equal to term1, you should first: const volVectorField gradUx=fvc::grad(Ux); gradUx.component(vector::X) = 0; gradUx.component(vector::Z) = 0; then you would have: gradUx = (0,Ux_y,0), an then applying: const volScalarField divgradUx=fvc::div(gradUx); you wpould have: (_x,_y,_z)*(0,Ux_y,0) = Ux_yy and term3 sould be same as term1 I am not sure about term2. |
July 11, 2018, 04:57 |
#20 |
Elham
Rep Power: 16 |
Dear Foamers,
In a multiphase fluid type, I have the following form of TEqn Code:
fvScalarMatrix TEqn ( fvm::ddt(T) + fvm::div(phi,T) - Foam::fvm::laplacian( k/rhoCp , T) ); TEqn.relax(); solve ( TEqn == fvc::ddt(p)*(1/rhoCp) +Foam::fvc::laplacian( D23*T , XV) ); Code:
rhogp= (rho2*limitedAlpha2+rho3*limitedAlpha3)/(limitedAlpha2+limitedAlpha3); XV= rho2/rhogp Code:
fvScalarMatrix TEqn ( fvm::ddt(T) + fvm::div(phi,T) - Foam::fvm::laplacian( k/rhoCp , T) - Foam::fvm::laplacian( D23*T , XV) ); TEqn.relax(); solve ( TEqn == fvc::ddt(p)*(1/rhoCp) ); Code:
gradientInternalCoeficients cannot be called for a calculatedFvPatchField Cheers, Elham |
Elementwise multiplication operator | johndeas | OpenFOAM Running, Solving & CFD | 3 | March 9, 2019 13:03 |
Question about the fvmatrix and Laplacian operator | liuhuafei | OpenFOAM Running, Solving & CFD | 6 | October 3, 2009 06:58 |
Operator declaration in Thermophysical library | lena | OpenFOAM Running, Solving & CFD | 0 | March 12, 2009 09:47 |
Material interfaces and the laplacian operator | cliffoi | OpenFOAM Running, Solving & CFD | 8 | November 8, 2006 08:57 |
Material interfaces using the laplacian operator | cliffoi | OpenFOAM | 0 | November 6, 2006 10:42 |
