Reading field values and setting them as boundary conditions |
July 7, 2009, 04:39 |
Sebastian Gatzka
Rep Power: 20 |
Hello World.
Let me introduce a problem I'm currently thinking about. Maybe we can brainstorm on it together? I'm dealing with a very complex mesh on which I have already performed a solution. Now I want to re-run a very 'closeup' investigation of a small region inside of this domain. So I was wondering if cutting this region and investigating it on its own can be done in this way... It is basically the following: I need to read internal field values from an existing case and set them as boundary conditions for another case. Let me explain this in some detail with the cavity case. Having found the solution of the case I want to use half of the domain for another case. Splitting the original mesh into two the original internal faces become boundary faces for the new case. What I want to achieve is that the values of the internal faces of the existing solution are somehow 'read' and then put as boundary conditions to the new case for each (existing) timestep while the solver is running on the new case. This may sound odd in case of the simple cavity case, but I'm confident it may be useful in my special case. Any help is appreciated. Have a nice day...
Schrödingers wife: "What did you do to the cat? It's half dead!" |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
Set nonuniform boundary values | nikwin | OpenFOAM Running, Solving & CFD | 1 | November 30, 2008 07:12 |
Boundary conditions | Marco Mazzieri | FLUENT | 0 | September 19, 2007 12:12 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 19:23 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 18:29 |
