Problem setting with chtmultiregionFoam
Old   April 22, 2009, 05:26
Lightbulb Problem setting with chtmultiregionFoam
Antonin
Antonin is on a distinguished road
I am using openfoam 1.5 on ubuntu (installed from ppa repo)
To get a quick summary: I want to simulate an hot fluid flow in a steel tube.
I am trying to setup a 3D case with chtmultiregionFoam, but I'm getting some trouble with it.I am starting from the tutorial one
(see http://www.cfd-online.com/OpenFOAM_D...eater-8318.unk ).With my new case, i get a segmentation faults.
My problem is, when I run chtmultiregion this message apair:
Create time
Create fluid mesh for region gaz for time = 0.001
Create solid mesh for region Solid for time = 0.001
*** Reading fluid mesh thermophysical properties for region gaz
Adding to pdf
Adding to thermof
Selecting thermodynamics package hThermo<pureMixture<constTransport<specieThermo<hC onstThermo<perfectGas>>>>>
Adding to rhof
Adding to Kf
Adding to Uf
Adding to phif
Adding to turb
Selecting RAS turbulence model kEpsilon
Adding to DpDtf
Adding to ghf
Updating p from pd
*** Reading solid mesh thermophysical properties for region Solid
Adding to rhos
Adding to cps
Adding to Ks
Adding to Ts
Region: gaz Courant Number mean: 0 max: 0.01
Region: gaz Courant Number mean: 0 max: 0.2994012
deltaT = 0.02994012
Time = 0.0309401
Solving for fluid region gaz
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
#0 Foam::error:rintStack(Foam::Ostream&) in "/usr/lib/OpenFOAM-1.5/lib/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/usr/lib/OpenFOAM-1.5/lib/libOpenFOAM.so"
#2 ?? in "/lib/libc.so.6"
#3 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::PatchFieldType const& Foam::fvPatch::lookupPatchField<Foam::GeometricFie ld<double, Foam::fvPatchField, Foam::volMesh>, double>(Foam::word const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const*, double const*) const in "/usr/lib/OpenFOAM-1.5/applications/bin/chtMultiRegionFoam"
#4 Foam::fvPatchField<double>::adddictionaryConstruct orToTable<Foam::solidWallHeatFluxTemperatureFvPatc hScalarField>::New(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/usr/lib/OpenFOAM-1.5/applications/bin/chtMultiRegionFoam"
#5 Foam::fixedGradientFvPatchField<double>::evaluate( Foam::Pstream::commsTypes) in "/usr/lib/OpenFOAM-1.5/applications/bin/chtMultiRegionFoam"
#6 Foam::gradientEnthalpyFvPatchScalarField::updateCo effs() in "/usr/lib/OpenFOAM-1.5/lib/libbasicThermophysicalModels.so"
#7 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::updateCoef fs() in "/usr/lib/OpenFOAM-1.5/lib/libfiniteVolume.so"
#8 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricFi eld<double, Foam::fvPatchField, Foam::volMesh>&, Foam::dimensionSet const&) in "/usr/lib/OpenFOAM-1.5/lib/libfiniteVolume.so"
#9 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacianUncorrected(Foam::GeometricFi eld<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/usr/lib/OpenFOAM-1.5/lib/libfiniteVolume.so"
#10 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/usr/lib/OpenFOAM-1.5/lib/libfiniteVolume.so"
#11 Foam::fv::laplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/usr/lib/OpenFOAM-1.5/lib/libfiniteVolume.so"
#12 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) in "/usr/lib/OpenFOAM-1.5/applications/bin/chtMultiRegionFoam"
#13 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/usr/lib/OpenFOAM-1.5/applications/bin/chtMultiRegionFoam"
#14 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/usr/lib/OpenFOAM-1.5/applications/bin/chtMultiRegionFoam"
#15 Foam::fvPatchField<double>::adddictionaryConstruct orToTable<Foam::solidWallTemperatureCoupledFvPatch ScalarField>::New(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/usr/lib/OpenFOAM-1.5/applications/bin/chtMultiRegionFoam"
#16 Foam::fvPatchField<double>::adddictionaryConstruct orToTable<Foam::solidWallTemperatureCoupledFvPatch ScalarField>::New(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/usr/lib/OpenFOAM-1.5/applications/bin/chtMultiRegionFoam"
#17 __libc_start_main in "/lib/libc.so.6"
#18 ?? in "/usr/lib/OpenFOAM-1.5/applications/bin/chtMultiRegionFoam"
Segmentation fault
I do not know where this error come,I think I misunderstood creatPatchDict set in the file system, but I'm not sure because I did not understand its usefulness.
For more information I have joind to my post my file system (system.tar.gz).If you have any solutions please don't esitate.
Thank you.
Antonin
Antonin is offline   Reply With Quote
Old   July 2, 2009, 05:09
Kyian Barrat
Khelian973 is on a distinguished road
Hi Antonin, Foamers
I have also a error message with chtMultiRegionFoam. It's not a segmentation fault, but maybe someone can help me or has an idea.
Create time
Create fluid mesh for region water for time = 0
Create solid mesh for region alu for time = 0
*** Reading fluid mesh thermophysical properties for region water
Adding to pdf
Adding to thermof
Adding to rhof
Adding to Kf
Adding to Uf
Adding to phif
Adding to turb
Selecting RAS turbulence model laminar
Adding to DpDtf
#0 Foam::error:rintStack(Foam::Ostream&) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/chtMultiRegionFoam"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam:perator/<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/chtMultiRegionFoam"
#6 main in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/chtMultiRegionFoam"
#7 __libc_start_main in "/lib/libc.so.6"
#8 Foam::regIOobject::readIfModified() in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/chtMultiRegionFoam"
Floating point exception
Thanks for any Help
Kyian
Khelian973 is offline   Reply With Quote
Old   July 20, 2009, 05:12
Default Error message chtMultiRegionFoam
Kyian Barrat
Hi Foamers,
I succeed to solve my problem to build the case and the different regions. But now i have another problem concerning the solver. Indeed, the calculations stop after around 10 iterations and I have this message
Solving for fluid region gn2
DILUPBiCG: Solving for h, Initial residual = 0.9297533, Final residual = 8.310485e-12, No Iterations 1
#3 Foam::hThermo<Foam:ureMixture<Foam::sutherlandTr ansport<Foam::specieThermo<Foam::hConstThermo<Foam :erfectGas> > > > >::calculate() in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#4 Foam::hThermo<Foam:ureMixture<Foam::sutherlandTr ansport<Foam::specieThermo<Foam::hConstThermo<Foam :erfectGas> > > > >::correct() in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#5 solveEnthalpyEquation(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::compressible::RASModel const&, Foam::basicThermo&) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/chtMultiRegionFoam"
I think it's probably due to the thermophysical properties, particularly sutherland Transport coefficient. But i double checked my figures and they are good.
If you have an idea, please
Kyian
Old   July 20, 2009, 06:52
Henrik Rusche
henrik is on a distinguished road
Dear Khelian973,
my bet is that the temperature is going below zero and then the sqrt(T) in the sutherlandTransport blows up.
Check your boundary and initial conditions and if correct try a smaller time step, more coupling until you you get a first time dump which you can inspect. Note that the regions are explicitly coupled - so please be gentle.
Henrik
henrik is offline   Reply With Quote
antonin
Problem setting C_MU_T with DEFINE_ADJUST Andy FLUENT 3 June 22, 2018 02:53
HELP!: swimming pool flow problem Tee FLUENT 1 September 8, 2005 08:29
Problem setting AV Marko CFX 0 March 18, 2005 08:06
Problem setting C_MU_T with DEFINE_ADJUST sarah_ron FLUENT 1 February 24, 2005 12:11
Help setting up combustor problem Tom FLUENT 0 February 5, 2005 01:20
