rhoSimpleform error
Old   July 21, 2009, 23:28
Default rhoSimpleform error
andesameer
Hi all,
Can you please let me know how to resolve following error.
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
Exec : rhoSimpleFoam
Date : Jul 21 2009
Time : 12:59:25
Host : bagvapp
PID : 3213
Case : /home/bagside/OpenFOAM/OpenFOAM-1.5/run/tutorials/rhoSimpleFoam/injectorthermal
nProcs : 1
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package hThermo<pureMixture<constTransport<specieThermo<hC onstThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 -0.33;
alphah 1;
alphak 1;
alphaEps 0.76923;
Starting time loop
Time = 1
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 1.11968e-06, No Iterations 7
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 7.16559e-06, No Iterations 6
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 3.83583e-06, No Iterations 6
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/bagside/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/bagside/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0x110400]
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/bagside/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/bagside/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/rhoSimpleFoam"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam:perator/<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/home/bagside/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/rhoSimpleFoam"
#6 main in "/home/bagside/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/rhoSimpleFoam"
#7 __libc_start_main in "/lib/libc.so.6"
#8 Foam::regIOobject::readIfModified() in "/home/bagside/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/rhoSimpleFoam"
Regards,
Sameer
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
