kinematicCloud initialization
Old   August 12, 2009, 09:34
Default kinematicCloud initialization
Alberto Passalacqua
I'm working with the lagrangian solvers, and I would need to initialize a closed domain with a uniform particle concentration field.
I checked the injection models, but the only possibility I found is to manually specify the particle position in a file, which is kind of hard if the domain is not elementary and if the number of particles is high.
Any suggestion?
Thanks
Alberto Passalacqua
Old   October 15, 2013, 09:56
Default Re: KinematicCloud injection
Boxiong
Frollo is on a distinguished road
Hi, Alberto,
I also need to work with KinematicCloud in OpenFOAM 2.0, and it's been a long time since you initiated the thread. Have you got a satisfactory answer or solution to the problom?
Chuck
Frollo is offline   Reply With Quote
Initialization problem when using Axisymmetry BC Eduardo FLUENT 0 August 4, 2008 09:23
Initialization a student Siemens 2 May 19, 2006 12:55
compressor initialization paglia FLUENT 0 February 1, 2006 15:14
Mesh Initialization shakked Main CFD Forum 2 August 7, 2004 22:50
Mesh Initialization shakked FLUENT 1 August 5, 2004 09:41
