Specifying phase on both sides of a Boundary Condition?
Old   November 9, 2009, 18:21
Default Specifying phase on both sides of a Boundary Condition?
rassilon is on a distinguished road
Hi Folks,
I am running a simple two phase problem using interFoam (see attached, much simplified, diagram).
Phase 0 is water and Phase 1 is air, and on the left side I have placed an inletOutlet BC to allow movement of fluid in and out of the model.
However, on the 'external' side of the BC, Foam seems to default to Phase 1, and under certain circumstances, the model draws air in through the BC.
I really need the default external phase to be Phase 0, i.e. water, but I am unsure how to set this up? Where in the various dictionaries can I control what phase lies on the external side of the inletOutlet BC? Can this be done?
Any help would be greatly appreciated,
Many thanks,
R
rassilon is offline   Reply With Quote
Old   November 10, 2009, 03:32
Markus
navier-stokes is on a distinguished road
Hi!
In 0/alpha1.orig set the BC for the approriate patch to "type fixedValue;" and set "value 0;"
Be sure to copy 0/alpha1.orig to 0/alpha1 before starting the solver 'cause 0/alpha1 will be overwritten.
Regards
Markus
navier-stokes is offline   Reply With Quote
Old   November 10, 2009, 20:29
Originally Posted by navier-stokes View Post
Hi!
Regards
Markus
Hi Markus,
Thanks for taking the time to reply.
I have tried your suggestion, but my model is still drawing air in through the boundary condition. My 0/alpha1 file now looks like this:
Inlet-reservoir
type fixedValue;
value uniform 0;
Before I changed it, it looked like this:
Inlet-reservoir
type inletOutlet;
inletValue uniform 0;
value uniform 0;
However, both of these configurations are still allowing air to be drawn back in through the boundary condition. The device I am modelling requires fluid, the same a phase0 to be drawn back in.
Is there anything else that I need to alter to make this happen?
Cheers,
R
Old   November 11, 2009, 00:41
Hi Markus,
I have got it working properly now.
Thanks for your help.
R
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
How to create a new boundary condition ? awacs OpenFOAM Programming & Development 5 May 30, 2009 03:00
Calculated gradient boundary condition similar to gammaContactAngle adona058 OpenFOAM Running, Solving & CFD 0 September 26, 2007 15:23
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Pressure Boundary Condition Matt Umbel Main CFD Forum 0 January 11, 2002 10:06
