ggiCheck functionObject in 1.6-ext
Old   January 25, 2011, 21:52
Default ggiCheck functionObject in 1.6-ext
Chris Sideroff
cnsidero is on a distinguished road
Does anyone know how to enable to verbose reporting of the GGI information while a case is running? In 1.5-dev this was enabled by putting the following in the case's system/controlDict
functions
ggiCheck
type ggiCheck;
phi phi;
functionObjectLibs ("libsampling.so");
I tried it in 1.6-ext but complains that surfaces, forces, sets, forceCoeffs and probes are the only valid functions.
cnsidero is offline   Reply With Quote
Old   January 26, 2011, 06:31
Oliver Lauer
olauer is on a distinguished road
Instead of libsampling.so you have to use libcheckFunctionObjects.so, then it should work.
olauer is offline   Reply With Quote
Old   January 26, 2011, 20:03
Chris Sideroff
That was it. Thanks Oliver.
k-omega-SST model (OF 1.6) - turbulent flat plate cboss OpenFOAM Running, Solving & CFD 25 August 9, 2016 09:53
Process control functionObject Vetter OpenFOAM 4 January 14, 2011 10:38
problems in Two Phase flow using twoPhaseEulerFoam with OpenFoam 1.6 raagh77 OpenFOAM Running, Solving & CFD 0 March 6, 2010 05:11
OpenFOAM Version 1.6 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 0 July 27, 2009 17:55
GGI function ggiCheck in OF 15dev louisgag OpenFOAM Running, Solving & CFD 3 February 3, 2009 20:08
