Question on mass flow BC
Old   April 12, 2010, 11:40
Default Question on mass flow BC
James Baker
fijinx is on a distinguished road
If I am defining a fixed mass or volumetric flow rate on a simulation that uses wedge symmetry, do I define the fraction of flow rate for the cross section that I have modeled or the mass flow rate for the entire model? Thanks!
fijinx is offline   Reply With Quote
Old   April 15, 2010, 05:17
Aram Amouzandeh
mabinty is on a distinguished road
the flow rate is calculated with the modeled cross section, hence a isosceles triangle with opening angle of 5°.
cheers,
aram
mabinty is offline   Reply With Quote
Old   April 15, 2010, 11:37
James Baker
Thank you! So just to be clear (to make sure I understand) if I were doing pipe flow, and I wanted a mass flow of 100kg/sec at the inlet of the whole pipe I would only put 5kg/sec for the inlet at the wedge?
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
Mass flow boundary condition vivian Main CFD Forum 0 April 10, 2006 23:32
Mass flow rate Neser CFX 4 February 14, 2004 00:27
Determine mass flow rate along flow path Atit Koonsrisuk CFX 2 October 5, 2003 04:47
How are the mass flux and mass flow rate defined? Miles Siemens 2 November 7, 2002 08:45
