how to combine parts of MRFSimpleFoam and TurbFoam to create a new solver?
Old   May 3, 2010, 22:10
Default how to combine parts of MRFSimpleFoam and TurbFoam to create a new solver?
任芸
renyun0511 is on a distinguished road
hello all,
i am trying to combine parts of MRFSimpleFoam and TurbFoam to create a new solver.but i have some trouble. can someone help me ?
the following code is the new code modified based on MRFSimpleFOAM:
#include "fvCFD.H"
#include "incompressible/singlePhaseTransportModel/singlePhaseTransportModel.H"
#include "incompressible/RASModel/RASModel.H"
#include "MRFZones.H"
#include "IFstream.H"
#include "OFstream.H"
int main(int argc, char *argv[])
# include "setRootCase.H"
# include "createTime.H"
# include "createMesh.H"
# include "createFields.H"
# include "initContinuityErrs.H"
Info<< "\nStarting time loop\n" << endl;
for (runTime++; !runTime.end(); runTime++)
Info<< "Time = " << runTime.timeName() << nl << endl;
# include "readPISOControls.H"
# include "CourantNo.H"
// Pressure-velocity SIMPLE corrector
// Momentum predictor
tmp<fvVectorMatrix> UEqn
( fvm::ddt(U)
+ fvm::div(phi, U)
+ turbulence->divDevReff(U)
mrfZones.addCoriolis(UEqn());
UEqn().relax();
solve(UEqn() == -fvc::grad(p));
//PISO loop
for (int corr=0;corr<nCorr;corr++)
volScalarField rAU = 1.0/UEqn().A();
U = rAU*UEqn().H();
phi = (fvc::interpolate(U) & mesh.Sf())
+ fvc::ddtPhiCorr(rAU,U,phi);
adjustPhi(phi, U, p);
p.boundaryField().updateCoeffs();
mrfZones.relativeFlux(phi);
// Non-orthogonal pressure corrector loop
for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
fvScalarMatrix pEqn
fvm::laplacian(rAU, p) == fvc::div(phi)
pEqn.setReference(pRefCell, pRefValue);
pEqn.solve();
if (nonOrth == nNonOrthCorr)
phi -= pEqn.flux();
# include "continuityErrs.H"
// Explicitly relax pressure for momentum corrector
// Momentum corrector
U -= rAU*fvc::grad(p);
U.correctBoundaryConditions();
turbulence->correct();
runTime.write();
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
Info<< "End\n" << endl;
return(0);
I set 1200 steps. after calculation, i saw the redifual seems like a steady residual result from steady solver.why?
thanks in advance!
renyun0511 is offline   Reply With Quote
Model runs in icoFoam amp turbFoam but never in MRFSimpleFoam peter_watson OpenFOAM Running, Solving & CFD 0 April 1, 2008 09:02
