June 11, 2010, 03:51 |
time step continuity error
Rep Power: 16 |
Hi at all,
i am doing some simulation of a flow through a pistol valve using the simpleFoam-solver containing k-w-SST turbulence model. unfortunately my calculations often crash or when they run from start- to endtime, solution are diverging. maybe you have an idea, what can be improved to avoid such errors?! timeStep is calculated with CFL-No. <1. examples: 1) here the velocity component U_z increases. Code:
Time = 0.74498 DILUPBiCG: Solving for Ux, Initial residual = 2.50978e-05, Final residual = 8.49602e-07, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 2.54388e-05, Final residual = 2.2754e-06, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 8.85837e-06, Final residual = 1.02878e+13, No Iterations 1001 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00995054, No Iterations 108 DICPCG: Solving for p, Initial residual = 0.113132, Final residual = 0.00109658, No Iterations 32 DICPCG: Solving for p, Initial residual = 0.018198, Final residual = 0.00017058, No Iterations 98 time step continuity errors : sum local = 3.2839e+07, global = -124559, cumulative = -124377 63 additional processes aborted (not shown) Code:
Time = 0.36633 DILUPBiCG: Solving for Ux, Initial residual = 0.0126915, Final residual = 0.000657026, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.00954027, Final residual = 0.000545504, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.00808909, Final residual = 0.000426527, No Iterations 2 DICPCG: Solving for p, Initial residual = 7.40292e-07, Final residual = 9.93734e-08, No Iterations 45 DICPCG: Solving for p, Initial residual = 5.64208e-07, Final residual = 9.98093e-08, No Iterations 4 DICPCG: Solving for p, Initial residual = 1.38451e-07, Final residual = 9.08471e-08, No Iterations 1 time step continuity errors : sum local = 11.0104, global = -0.956176, cumulative = 62676.9 63 additional processes aborted (not shown) And what can in general be said about the duration the user should define (startTime /endTime)? Is there any relation between this defined time and the physical time which the fluid needs to flow trough the geometry? or is most priority that the variable we are looking for, is converged? |
June 11, 2010, 04:05 |
#2 | |
Stefan Herbert
Rep Power: 17 |
Hi bephi,
simpleFoam is a solver for steady state problems. Therefore the time step has no effect on solution, convergence, etc. The first step to improve stability is to reduce relaxation factors. Quote:
Regards, Stefan |
June 11, 2010, 04:25 |
Rep Power: 16 |
Hi thanks for your answer.
Which URF should be decreased in your opinion? Regards! Philipp |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
