June 24, 2010, 09:49 |
turbFoam
asmi
Hello!
I am using turbFoam to do a transient analysis. First I made a steady state analysis with simpleFoam but the results weren't good. So i decided to choose turbFoam , i changed the fvSchemes and fvSolution file but when i run , it stops : Exec : turbFoam -parallel Date : Jun 24 2010 Time : 10:13:20 Host : Foam1 PID : 1883 Case : /media/OpenFoam/Travaux/p-habitacle/foamProMesh-pisoFoam/pisoFoam nProcs : 30 Slaves : 29 ( Foam1.21884 Foam1.21885 .... Foam8.20214 ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model realizableKE Starting time loop FunctionObject:fieldProcess:fieldProcess FunctionObject:volumeReport:volStats Logging volume statistics to file: "/media/OpenFoam/Travaux/p-habitacle/foamProMesh-pisoFoam/pisoFoam/processor0/../log/volStats_volumeStatistics.0" Time = 1 Courant Number mean: 4.93168701749 max: 62294.1691783 [2] [2] [2] request for surfaceScalarField UBlendingFactor from objectRegistry region0 failed available objects of type surfaceScalarField are 3 ( weightingFactors differenceFactors_ phi ) #0 Foam::error:rintStack(Foam::Ostream&) in "/media/OpenFoam/FOAMpro/FOAMpro-1.5-2.2/FOAM-1.5-2.2/lib/linux64GccDPOpt/libFOAM.so" #1 Foam::error::abort() in "/media/OpenFoam/FOAMpro/FOAMpro-1.5-2.2/FOAM-1.5-2.2/lib/linux64GccDPOpt/libFOAM.so" #2 Foam::Ostream& Foam:perator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) in "/media/OpenFoam/FOAMpro/FOAMpro-1.5-2.2/FOAM-1.5-2.2/applications/bin/linux64GccDPOpt/turbFoam" #3 Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const& Foam:bjectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvsPatchField, Foam::surfaceMesh> const>(Foam::word const&) const in "/media/OpenFoam/FOAMpro/FOAMpro-1.5-2.2/FOAM-1.5-2.2/lib/linux64GccDPOpt/libfiniteVolume.so" #4 Foam::localBlended<Foam::Vector<double> >::weights(Foam::GeometricField<Foam::Vector<doubl e>, Foam::fvPatchField, Foam::volMesh> const&) const in "/media/OpenFoam/FOAMpro/FOAMpro-1.5-2.2/FOAM-1.5-2.2/lib/linux64GccDPOpt/libfiniteVolume.so" #5 Foam::fv::gaussConvectionScheme<Foam::Vector<doubl e> >::fvmDiv(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const in "/media/OpenFoam/FOAMpro/FOAMpro-1.5-2.2/FOAM-1.5-2.2/lib/linux64GccDPOpt/libfiniteVolume.so" #6 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::div<Foam::Vector<double> >(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) in "/media/OpenFoam/FOAMpro/FOAMpro-1.5-2.2/FOAM-1.5-2.2/applications/bin/linux64GccDPOpt/turbFoam" #7 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::div<Foam::Vector<double> >(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) in "/media/OpenFoam/FOAMpro/FOAMpro-1.5-2.2/FOAM-1.5-2.2/applications/bin/linux64GccDPOpt/turbFoam" #8 main in "/media/OpenFoam/FOAMpro/FOAMpro-1.5-2.2/FOAM-1.5-2.2/applications/bin/linux64GccDPOpt/turbFoam" #9 __libc_start_main in "/lib64/libc.so.6" #10 __gxx_personality_v0 at /usr/src/packages/BUILD/glibc-2.3/csu/../sysdeps/x86_64/elf/start.S:116 [2] [2] [2] From function objectRegistry::lookupObject<Type>(const word&) const [2] in file /users/echidna01/jacques/IconReleases//FOAMpro-1.5-2.2/FOAM-1.5-2.2/src/FOAM/lnInclude/objectRegistryTemplates.C at line 142. [2] FOAM parallel run aborting [2] This happens even when I lower the time step to a small value. Am I perhaps doing something wrong when going to transient? I simply set the start time, in controlDict, as the number of the latest iteration from the steady state case in whose folder all variables are saved. Will my boundary conditions be preserved now? Is this the right way to do it or am i missing something here....or somewhere else... Any ideas appreciated!! |
June 29, 2010, 05:08 |
Are you using the localBlended scheme somewhere in your fvSchemes file?
If you are using that scheme, you have to implement a surfaceScalarField called UBlendingFactor in turbFoam, so that the localBlended scheme does know, which of the two provided schemes to use at which point of your computational domain. AFAIR, the values of UBlendingFactor should be somewhere between 1 and 0. I hope this helps, Jens |
turbfoam problem |
time Step's turbFoam >>> exit | mgolbs | OpenFOAM Pre-Processing | 4 | December 8, 2009 03:48 |
how to use 'turbFoam standard k-Epsilon ?' | panda60 | OpenFOAM | 0 | October 22, 2009 06:27 |
turbFoam vs CFX - 2D case high Re | ffucile | OpenFOAM Running, Solving & CFD | 17 | October 21, 2009 04:01 |
SimpleFoam result for turbFoam initialisation | philippose | OpenFOAM Running, Solving & CFD | 0 | November 26, 2006 10:24 |
Differences between simpleFoam an turbFoam | francois | OpenFOAM Running, Solving & CFD | 3 | November 15, 2005 14:03 |
