Boundary Conditions. Simulation cylinder.
Like Tree1Likes
Old   October 7, 2010, 02:35
maddalena's Avatar
maddalena
maddalena will become famous soon enough
Originally Posted by T.D. View Post
This is the drawing attached
what about the outer cylinder shape? The lateral side that connects the two disks I mean
mad
maddalena is offline   Reply With Quote
Old   October 7, 2010, 02:53
Post hi
  #22
T.D. is on a distinguished road
hi,
nothing connect them it is a free surface
but in drawing it will be a cylinder where i must apply a certain BC on the outer side
T.D. is offline   Reply With Quote
Old   October 7, 2010, 03:19
maddalena's Avatar
maddalena
nothing connect them it is a free surface but in drawing it will be a cylinder where i must apply a certain BC on the outer side
I have no experience on this kind of things, but what I would say is that if you apply any BC on those sides, they will affect your inner field. Thus if there is nothing connecting them, I would insert the two geometries on a large domain (a sphere?) and apply a inletOutlet BC on the outer (spherical) surface.
This is only an idea. Maybe someone has more experience on the subject...
mad
Old   October 7, 2010, 04:38
Default hi
  #24
hi
lets consider from out it is closed wall
my question was how to create the cylinder geometry in openfoam
do i need to insert point point, it will be hard?
how to draw? is there any software that i can draw in and then convert to blockMesh file?
help please
thanks a lot
Old   October 7, 2010, 04:44
maddalena's Avatar
maddalena
What??
Help please, and what about the BCs?
If I am not wrong, you asked help for BC as well!!!
You can use any software you want to create your mesh, and then convert it for OpenFOAM. Is not necessary to go through blockMesh, if you create your geometry ie in Gambit or in Pointwise or in Salome.
mad
Old   October 7, 2010, 06:10
Default ok
  #26
ah ok thanks a lot
boundary conditions, simulation cylinder
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
[ICEM] Problem with boundary layers for cylinder in channel nik ANSYS Meshing & Geometry 0 October 27, 2009 06:01
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Need help about boundary conditions for a francis runner flow simulation Rodrigo Escobar Moragas Main CFD Forum 1 October 26, 1998 08:20
