SimpleFOAM + SST-Model + problem with convergence
Old   November 9, 2010, 04:43
Default SimpleFOAM + SST-Model + problem with convergence
Antoine Devesa
A.Devesa is on a distinguished road
Hello everybody,
i observe some strange behavior in the convergence process of my simulations. Since i could reproduce the bug on different machines, i am now very sure, it's a problem with OF and not a hardware problem (like a memory bug)...
Did somebody observe these jumps as well? Does anybody have a tip to solve that?
The main problem is that the values (here on the graph, the drag for example) are landing on different levels after those "jumps"... Which makes the convergence last much longer, and may be false!
My setup:
- 46 Mcells mesh, converted from fluent format
- simulating with simpleFoam 1.7.x
- k-omega-SST-Model
- Pressure solving: GAMG with tolerance 1e-7
- Velocity and k/omega solving: PBiCG with tolerance 1e-8
- relaxationFactors: p 0.3; 0.7 for the rest
Thank you!
Antoine
A.Devesa is offline   Reply With Quote
convergence, forces, jumps
2D SST Simulation Airfoil - Convergence Problem Kraemer CFX 10 April 16, 2011 07:22
Convergence problem with thermal phase change model under low velocity conditions pitisrisuk CFX 0 July 21, 2009 11:21
simulation results for k-w model and SST model Li CFX 7 June 29, 2007 04:19
CONVERGENCE PROBLEM - oil boiler MM FLUENT 1 February 15, 2007 05:24
convergence problem with SIMPLER NURAY KAYAKOL Main CFD Forum 1 February 24, 1999 13:43
