Comparison of results calculated by OpenFOAM's turbulent model kwSST in weir flow |
March 22, 2023, 05:13 |
YJ-Kwon
Rep Power: 3 |
Hello guys.
I am not good at English, so there may be some awkward parts in the question. I would appreciate it if you could understand this. I calculated with OpenFOAM following the same weir case as the paper, but I don't know if this result is correct. The turbulence model used k-w SST. The flow away from the weir end is different from the picture in the paper. I think it's normal if the same flow as the attached second picture continues to come out continuously. However, the calculated flow converges after a certain period of time, just like the picture I calculated in the first picture. The attached second picture is described as a capture of the instantaneous flow in the paper. I want to know if the weir case I calculated is well calculated, is there a post to refer to, or I'm wondering if you guys have any opinions. Thank you for reading my post. |
March 22, 2023, 12:31 |
Santiago Lopez Castano
Rep Power: 15 |
You are experiencing a problem that also happens on physical experiments: lack of areation behind the jet. Make sure to leave a pressure inlet in the jump region in order to allow air to enter.
March 23, 2023, 00:36 |
Uwe Pilz
Rep Power: 15 |
For me, it looks like you used a sReynolds number much lower than in the reference work. Could you give the numbers, please?
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
March 23, 2023, 00:56 |
YJ-Kwon
Rep Power: 3 |
March 23, 2023, 01:00 |
YJ-Kwon
Rep Power: 3 |
March 23, 2023, 01:32 |
abdikerim kurbanaliev
Rep Power: 15 |
which version of the package did you use? Is that OF6?
March 23, 2023, 01:39 |
YJ-Kwon
Rep Power: 3 |
No, to be exact, v2206 on www.openfoam.com
k-w-sst, open channel flow, weiroverflow |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Transient thermal deviating results | RichardL | ANSYS | 0 | June 6, 2018 10:28 |
How to model a turbulent flow over a cylinder? | Mahbub | FLUENT | 14 | February 10, 2018 11:14 |
porous media turbulent model P-dL, I get the different results? is the model wrong? | hitchenxue | FLUENT | 0 | July 13, 2014 05:57 |
Need experimental results on turbulent flow | babyface | Main CFD Forum | 1 | May 22, 2002 12:52 |
