January 10, 2006, 15:23 |
Servus,
I have tried out a
Oliver Borm
Rep Power: 17 |
Servus,
I have tried out a icoTopoFoam case. I began at the mixer2D tutorial. Then I changed the mesh like in this case http://www.cfd-online.com/OpenFOAM_D...tml?1123794946 But not radial only axial and very simple only with 32 points. I have made like a rotor/stator with each three blocks. Before and behind the blades the boundary condition is cycil. The sliding b.c. is betwenn rotor and stator. Do I need the celltoRegion file? The configuration is running, but is than aborted. The failure is like: Time = 0.0005 Total volume change: 4.51028e-17 ICCG: Solving for p: solution singularity BICCG: Solving for Ux, Initial residual = 1.57256e-06, Final residual = 2.47283e-23, No Iterations 1 BICCG: Solving for Uy, Initial residual = 1.68984e-06, Final residual = 5.24896e-23, No Iterations 1 BICCG: Solving for Uz, Initial residual = 8.34627e-07, Final residual = 3.83218e-23, No Iterations 1 ICCG: Solving for p, Initial residual = 0.424909, Final residual = 6.8224e-07, No Iterations 13 time step continuity errors : sum local = 1.56593e-296, global = 6.73108e-298, cumulative = 0.00314565 time step continuity errors : sum local = 1.56593e-296, global = 6.73108e-298, cumulative = 0.00314565 time step continuity errors : sum local = 1.56593e-296, global = 6.73108e-298, cumulative = 0.00314565 time step continuity errors : sum local = 1.56593e-296, global = 6.73108e-298, cumulative = 0.00314565 Mean and max Courant Numbers = 3.8738e-287 5.44948e-286 deltaT = 1.30217e-298 ExecutionTime = 14.98 s Time = 0.0005 Total volume change: 4.51028e-17 ICCG: Solving for p: solution singularity BICCG: Solving for Ux, Initial residual = 1.55853e-06, Final residual = 5.80535e-23, No Iterations 1 BICCG: Solving for Uy, Initial residual = 1.67476e-06, Final residual = 7.41848e-23, No Iterations 1 time step continuity errors : sum local = nan, global = nan, cumulative = nan time step continuity errors : sum local = nan, global = nan, cumulative = nan time step continuity errors : sum local = nan, global = nan, cumulative = nan time step continuity errors : sum local = nan, global = nan, cumulative = nan Mean and max Courant Numbers = nan nan deltaT = 0.2 ExecutionTime = 15.03 s Time = 0.2005 --> FOAM FATAL ERROR : Bad points. From function void plane::calcPntAndVec ( const point&, const point&, const point& ) in file meshes/primitiveShapes/plane/plane.C at line 108. FOAM aborting Can anyone help me? I can also post the b.c. and the blockMeshDict if it is helpful. If I get the case to be run. I can it post as a turbomachinery tutorial. |
partcle tracking (aborted trapped incomplete) | Fabrizio | FLUENT | 4 | September 21, 2007 12:15 |
No icotopoFoam | alice | OpenFOAM Running, Solving & CFD | 0 | August 17, 2007 05:58 |
IcoTopoFoam | derath | OpenFOAM | 1 | April 25, 2006 08:23 |
IcoTopoFoam | giampippetto | OpenFOAM Running, Solving & CFD | 4 | March 22, 2006 05:34 |
Reg "DPM-particle aborted" | GANESH | FLUENT | 3 | March 7, 2006 09:45 |
