simpleWindFoam Explicit Source
Old   March 18, 2011, 05:14
Default simpleWindFoam Explicit Source
Tom
tidal_Tom is on a distinguished road
Hi, I have been using OpenFOAM 1.7.1 for a few months now to simulate tidal turbines in channel flow. I have been using the simpleWindFoam solver that is included in the tutorials with version 1.7.1. It uses the field sources located at:
/SRC/finiteVolume/cfdTools/general/fieldSources/basicSource/
It runs fine when I select an actuatordisk as the source. However I would like to use the explicit source so I can add a turbulece, k and epsilon, term at the disk. However when I do so I get the following message:
Selecting model type explicitSource
Source: turb
- selecting cells using cellSet actuationDisk1
- selected 896 cell(s) with volume 3.888201e-06
--> FOAM FATAL ERROR:
header not OK
From function explicitSource::setFieldData
in file cfdTools/general/fieldSources/basicSource/explicitSource/explicitSource.C at line 153.
FOAM exiting
I do not understand the error. I simply copied the explicit source definition from the basicSource.H file and added it to the sourceProperties file located in the constant directory of the model.
can anyone help?
tidal_Tom is offline   Reply With Quote
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
