Fixed heat flux BC in buoyantPimpleFoam
Like Tree30Likes
Old   June 30, 2011, 03:45
Aram Amouzandeh
mabinty is on a distinguished road
Originally Posted by murrdpirate View Post
Thanks. I didn't realize there were examples in the code for these things.
Issue now is that it's saying "KName is undefined." As you showed, that's not listed in the example. I see somewhere online that it's "CHARACTER*(*) array of species names," but I don't know what that means
It would be easier to figure out the problem if we can see the exact error message! Try to add the line:
KName          K;
Check src/turbulenceModels/compressible/turbulenceModel/derivedFvPatchFields/temperatureCoupledBase/temperatureCoupledBase.C to see what is happening with "KName".
Cheers,
Aram
murrdpirate likes this.
mabinty is offline   Reply With Quote
Old   June 30, 2011, 17:53
Kevin
murrdpirate is on a distinguished road
Here's the error I get when KName isn't defined:
--> FOAM FATAL IO ERROR:
keyword KName is undefined in dictionary "/home/kevin/OpenFOAM/kevin-2.0.0/run/dormCool/0/T::boundaryField::window"
file: /home/kevin/OpenFOAM/kevin-2.0.0/run/dormCool/0/T::boundaryField::window from line 44 to line 49.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 400.
FOAM exiting
Your suggestion to add "KName K;" made sense and actually did allow my case to calculate as normal, but for some reason I get the following error when I try to view the data in paraView (I also get the same error when running reconstructPar if I calculated in parallel):
Cannot find 'value' entry on patch walls of field T in file "/home/kevin/OpenFOAM/kevin-2.0.0/run/dormCool/0.0005/T"
which is required to set the values of the generic patch field.
(Actual type compressible::turbulentHeatFluxTemperature)
Please add the 'value' entry to the write function of the user-defined boundary-condition
file: /home/kevin/OpenFOAM/kevin-2.0.0/run/dormCool/0.0005/T::boundaryField::walls from line 77556 to line 83919.
From function genericFvPatchField<Type>::genericFvPatchField(con st fvPatch&, const Field<Type>&, const dictionary&)
in file genericFvPatchField/genericFvPatchField.C at line 71.
FOAM exiting
Again, thanks for the help, I do feel like I'm at least getting there. I'll look into this a little bit more tonight when I have time and share what I find.
murrdpirate is offline   Reply With Quote
Old   June 30, 2011, 23:21
Mark Pitman
pitmanm is on a distinguished road
I can confirm that this error occurs also when attempting to recomposePar a model that makes use of turbulentHeatFluxTemperature boundary condition.
It appears to be a bug in the turbulentHeatFluxTemperature boundary condition in OpenFOAM 2.0 where this BC does not write the "value" entry for this BC. A look at the code seems to confirm this.
I am thinking of copying the BC to create a user-defined boundary condition which fixes the problem of writing the 'value' entry. Does anyone else know of a fix or workaround that I may not have considered?
pitmanm is offline   Reply With Quote
Old   July 7, 2011, 07:18
Cool
  #24
Mauro Arruda
mauro.p.arruda@gmail.com is on a distinguished road
hi pitmanm,
have you been able to get around the bug?
Get the same problem when converting the time directories for post-processing.
I just started looking into it and will let you know if i'm lucky or not
Cheers,
Mauro
mauro.p.arruda@gmail.com is offline   Reply With Quote
Old   July 7, 2011, 13:24
Mark Pitman
Hi Mauro,
I have not had a chance as of yet because I've been so busy with work. The change in the code is pretty easy it is just actually just getting the fvPatchScalarField to work as a user-defined BC I have found tricky. Do you need to do it all as template classes? Then just define <scalar> perhaps?
Cheers,
Mark
Old   September 2, 2011, 07:52
Maria Jaromin
jaromin is on a distinguished road
"The problem is that the postprocessing utilities do not know about that b.c. so do not know how to read it (it is derived from a fixedGradient b.c. which does not need a 'value' field).
If you add the library that contains the compressible::turbulentHeatFluxTemperature to your 'libs' section in the system/controlDict it should work.
libs ("libcompressibleTurbulenceModel.so"); "
see: http://www.openfoam.com/mantisbt/view.php?id=285
Maria
bhh likes this.
jaromin is offline   Reply With Quote
Old   September 19, 2012, 12:33
anonymous
socrates is on a distinguished road
I am trying to apply a constant BC on micro-tubes surfaces inside a substrate. I have tried these:
1.
type fixedGradient;
gradient uniform -10000;
2.
type groovyBC;
gradientExpression "-10000";
fractionExpression "0";
3.
type groovyBC;
value uniform 300;
gradientExpression "gradT";
variables "htot=15000.00;Tinf=293.00;k=130;gradT=htot/(k)*(Tinf-T);";
The results show different gradient values on the walls, gradTx, gradTy and gradTz are so much more that the input values. I should mention that when I apply this BC for top surface which is horizontal I get perfect results. Here it says ( http://www.foamcfd.org/Nabla/guides/...Guidese11.html) that by "fixedgradient" we define
. I need to define only the magnitude of temperature gradient on the tubes.
Could you help me please?
Thank you
aa
socrates is offline   Reply With Quote
Old   September 21, 2012, 02:48
Matthias Hettel
matthi is on a distinguished road
Hello Socrates,
I don`t understand your physical problem and why you need a fixed gradient. May be you could also use a fixed heat flux?
Nevertheless, I have some experience in defining boundary conditions for solid regions. Maybe, you find something useful in the solver:
OpenFOAM-1.7.\applications\solvers\heatTransfer\chtMultiReg ionSimpleFoam
The boundary conditions can be find in the subfolder
derivedFvPatchFields\solidWallHeatFluxTemperature
Good luck
Matthi
matthi is offline   Reply With Quote
Old   May 30, 2013, 22:21
George Pichurov
jorkolino is on a distinguished road
Originally Posted by mabinty View Post
That means you did not specify how the conductivity fied "K" shoud be calculated. Look at the top of src/turbulenceModels/compressible/turbulenceModel/derivedFvPatchFields/turbulentHeatFluxTemperature/turbulentHeatFluxTemperatureFvPatchScalarField.H:
hotWall
            type            compressible::turbulentHeatFluxTemperature;
            heatSource      flux;        // power [W]; flux [W/m2]
            q               uniform 10;  // heat power or flux
            K               basicThermo; // calculate K by alphaEff*thermo.Cp
            value           uniform 300; // initial temperature value
Cheers,
Aram
In my case, the error message says keyword alphaEff is undefined. Shall I use the same assignment as for the K keyword above? Forgot to mention, my solver buoyantBoussinesqSimpleFoam. Nope, it does not work, I tried define the alphaEff keyword as above, but it is rejected as a valid entry in the basicThermo.
jorkolino is offline   Reply With Quote
Old   January 29, 2015, 01:49
Default please suggest how to solve this error
  #30
Rahul
rahulps is on a distinguished road
keyword kappa is undefined in dictionary "/home/rahulps/OpenFOAM/rahulps-2.2.2/run/conjugate1/0/solid/T.boundaryField.solid_to_fluid"
file: /home/rahulps/OpenFOAM/rahulps-2.2.2/run/conjugate1/0/solid/T.boundaryField.solid_to_fluid from line 41 to line 45.
in file db/dictionary/dictionary.C at line 402.
FOAM exitin
rahulps is offline   Reply With Quote
Old   March 10, 2015, 09:21
Unhappy error: keyword alphaEff is undefined in dictionary
  #31
Naresh Yathuru
Naresh yathuru is on a distinguished road
Hi Foamers,
I m using openFoam 2.3.0 and the solver is buoyantBoussinesqsimpleFoam. I am simulating a room with a cube inside i have to impose heat flux boundary conditions..Therefore i applied turbulentHeatFluxTemperature bc for the patch as follows
innercube
type turbulentHeatFluxTemperature;
heatSource flux; //power;
q uniform 100;
value uniform 293.0;
Now i m getting a error as innercube
keyword alphaEff is undefined in dictionary "/home/yathuru/praktikum/noniso/heat_transfer_flux/processor7/0/T.boundaryField.innercube"
[7]
[7] file: /home/yathuru/praktikum/noniso/heat_transfer_flux/processor7/0/T.boundaryField.innercube from line 40 to line 43.
[7]
[7] From function dictionary::lookupEntry(const word&, bool, bool) const
[7] in file db/dictionary/dictionary.C at line 437.
[7]
FOAM parallel run exiting
I have read in the forum that i should change kappaeff to alphaeff in th Tequ.H but it turns out the new version already has the changes implimented. so i m not sure where i m went wrong.
could someone please help help me. im desperate for help.
Naresh yathuru is offline   Reply With Quote
Old   March 10, 2015, 09:23
Naresh Yathuru
Hi rahul and george
i have a similar error how did u alble to solve your error coul you please help me.
Thankyou
regards,
Naresh
Old   March 11, 2015, 03:47
Agustín Villa
agustinvo is on a distinguished road
Originally Posted by Naresh yathuru View Post
Hi Foamers,
innercube
q uniform 100;
alphaEff alphaEff;
[7]
[7]
[7]
Hello
You have to declare inside your BC which variable would be your alphaEff. Otherwise the BC code cannot continue.
In relation with the name of the variable, it does not matter if you have defined it in the solver. So you could put
alphaEff alphaEff;
or
alphaEff kappaEff;
agustinvo is offline   Reply With Quote
Old   March 11, 2015, 05:27
Naresh Yathuru
Hi augstin villa and other Foamers,
Thanks for your reply.
It took me a some time to find it out and itseems nobody left any trace of the changes in new version but i m glad to share this. In openFoam version 2.3.0 the thermal diffusivity kappaeff in turbulence heatflux temperature is already replacded to alphaeff.
And aditionally u have to include Cp0 Cp0 1005 in the ttransport properties. Note (no dimention for Cp0)
Fore more details check turbulenceheatfluxtemperature.H
hope this would help people like me who arre new to openFoam
Regards,
Naresh
agustinvo likes this.
Old   November 26, 2016, 18:31
alberto
dewey is on a distinguished road
Hi
Do you know how i can use the heat flux as Bc on a wall with a buoyantBoussinesqSimpleFoam, something like INcompressible::turbulentHeatFluxTemperature??
dewey is offline   Reply With Quote
Old   November 26, 2016, 18:34
alberto
i found this
https://github.com/OpenFOAM/OpenFOAM...hScalarField.H
But when i search in my OF 4.1 i cant find it, and i dont know how to add it.
Old   November 27, 2016, 05:06
Agustín Villa
Originally Posted by dewey View Post
i found this
Hello dewey,
last week I have been working in the code to use the compressible::turbulentHeatFluxTemperature in a incompressible solver. I can share with you the code, but it would be tomorrow.
jeanpinto24| likes this.
Old   May 21, 2017, 07:40
Default Query
  #38
jeanpinto24@hotmail.com
jeanpinto24| is on a distinguished road
I have a doubt. In my case I have to add the heat contributed by the people in my simulation. The question that comes to me when using the BC: turbulentHeatFluxTemperature will I see in my simulation the outflow of heat from the wall?
jeanpinto24| is offline   Reply With Quote
Old   August 25, 2017, 09:05
Ketan Ganatra
ketanganatra0@yahoo.com is on a distinguished road
it is the mode that you have to define either flux or power
kappa fluidThermo; // calculate kappa=alphaEff*thermo.Cp
Qr none; // name of the radiative flux
ketanganatra0@yahoo.com is offline   Reply With Quote
Old   January 12, 2019, 08:51
Jianrui Zeng
calf.Z is on a distinguished road
is used as initial value at the respective patch. To check wall heat fluxes use the "wallHeatFlux" utility.
Aram
If I use wallHeatFlux to check the heat flux. Should the value be the same as the setting one in externalWallHeatFluxTemperature BC ? If the two values are different, what is the reason of it? Thank you.
calf.Z is offline   Reply With Quote
Total heat transf. rate vs Total surface heat flux Renato Sousa FLUENT 1 April 14, 2020 03:27
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 16:25
Variable name for heat flux peterle CFX 4 February 13, 2014 02:21
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 12:20
Heat flux in ansys cfx juliom OpenFOAM Running, Solving & CFD 2 April 14, 2009 14:30
