Foam FATAL ERROR: janafThermo ? r
Old   June 17, 2011, 05:34
Default Foam FATAL ERROR: janafThermo ? r
lfgmarc's Avatar
Luis Felipe Gutierrez Marcantoni
lfgmarc is on a distinguished road
Send a message via MSN to lfgmarc
Hi, I test a modified case of the pitzDaily tutorial case, with another geometry, I test the case with and inlet velocity of 5 and 5 m/s, but when I increment the velocity to 30 m/s this error appear:
Hi, I tested a modify case of the pitzDaily tutorial with XiFoam solver , with another geometry, I tested the case, with an inlet velocity of 5 and 15 m/s and the results are ok, but when I increment the velocity to 30 m/s this error appear:
--> FOAM FATAL ERROR:
attempt to use janafThermo<equationOfState> out of temperature range 100 -> 5000; T = 19.6831
From function janafThermo<equationOfState>::checkT(const scalar T) const
in file /home/openfoam1.7/OpenFOAM/OpenFOAM-1.7.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 63.
I was thinking that the problem maybe arise from the time step, because the mesh is the same. only the velocity at inlet was changed.
Anyone have some idea about what can be the problem ?
Thanks,
Fg
Pd: sorry for my poor english.
Felipe G
lfgmarc is offline   Reply With Quote
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
