error while running circCylinder3d tutorial case in foam-extand 3.1 |
February 3, 2017, 11:48 |
ZHENKAI ZHAO
Rep Power: 10 |
I am trying to address large mesh deformation with tet mesh.
I have searched the web and found that dynamicTopoFvMesh working with mesquiteMotionSolver should be able to replace my current motion solver "displacementSBRStressFvMotionSolver". I have installed foam-extend 3.1 and ran the tutorial case for dynamicTopoFvMesh: circCylinder3d. But after when T = 1.1s, the process stopped with an error like below: --> FOAM FATAL IO ERROR: size 104 is not equal to the given value of 105 file: IStringStream.sourceFile::topWall from line 2 to line 11. From function Field<Type>::Field(const word& keyword, const dictionary&, const label) in file /home/zzkzzk2015/foam/foam-extend-3.1/src/foam/lnInclude/Field.C at line 239. FOAM exiting I have checked the moving patch data in each time step and found the elements of the patch is 104. But why the elements at T = 1.1s suddenly changes to 105? Or probably I have used the wrong version of foam-extend? I am completely new the foam-extend. I hope someone can give me some clues so that I can have an access to the problem. Thanks a lot ZHENKAI |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 15:13 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
gmsh2ToFoam | sarajags_89 | OpenFOAM | 0 | November 24, 2009 22:50 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
