Can I specify the write/data output directory? |
Shawn
Rep Power: 14 ![]() |
Is there any way to specify the data output / write directory? I assume this would be done in controlDict, but I haven't been able to find anything thta will do it. It would be nice if I could create a directory called "Results" or "Solution" or whatever and have all my timesteps, forces, etc. written there instead of into the case directory.
Thanks Shawn |
David Gaden
Rep Power: 22 ![]() |
You can only specify a subdirectory.
See the wiki: http://openfoamwiki.net/index.php/Op...objectRegistry The output goes to the IOobject's path, which can is: instance/local/name You give it the "instance" and (optionally) "local" when you create the IOobject. name is its name, and that becomes the filename. instance can only be one of 5 things. See the wiki.
~~~ Follow me on twitter @DavidGaden |
OpenFoam install script Error during paraFoam installation | SePe | OpenFOAM Installation | 10 | June 19, 2010 15:15 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
Re : Problem Installing OpenFOAM on Centos -5.3 | mohanphy | OpenFOAM Installation | 1 | February 7, 2010 19:09 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 09:50 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 06:43 |
