[swak4Foam] settings a gradient on boundary using groovyBC
Old   November 10, 2011, 09:36
Default settings a gradient on boundary using groovyBC
gfilip is on a distinguished road
I am experimenting with groovyBC and can successfully use the valueExpression on a patch. When I try to set a gradientExpression for pressure, such as:
inlet
        type            groovyBC;
        //valueExpression               "100";
        gradientExpression      "100";
and then calculate the normal gradient of pressure on the inlet, I get non-constant values much different than 100. When using the gradientExpression I also obtain a 0 pressure on the inlet boundary. I also tried using:
gradientExpression "vector(100,0,0)&normal()" but that gives the same result.
This is a simple 2D case with an oscillatingFixedValue velocity inlet ran using pisoFoam.
Am I interpreting the gradientExpression patch parameter wrong?
gfilip is offline   Reply With Quote
Old   November 10, 2011, 11:11
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
From the documentation:
* fractionExpression
   Determines whether the face is Dirichlet (1) or Neumann (0). Defaults to 1
You can probably see the problem. Fix fractionExpression and all will be good.
akidess is offline   Reply With Quote
Old   November 10, 2011, 11:14
Hi Anton,
I have in fact tested the fractionExpression as well, but setting it to 0 did not help.
Old   November 10, 2011, 19:37
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
inlet
        type            groovyBC;
I'm just wondering whether I'm misinterpreting your posting. "I get non-constant values much different than 100" Do you mean "I calculated the gradient using the value in the next cell and the delta coefficient and it was much different from 100". In that case there is a problem. Or did you mean "'value' on the patch is different from 100". That is to be expected because you're only setting the gradient on the patch (basically the relative change to the next cell) NOT the value with a Neuman condition
gschaider is offline   Reply With Quote
Old   May 3, 2012, 10:05
Albert Tong
tfuwa is on a distinguished road
Hi All,
I would like to set up a gradient B.C., ∂p/∂x = cos (2*pi*t) .
Is there a way to do this with groovyBC or openfoam official tools?
Cheers.
Kind regards,
Albert
tfuwa is offline   Reply With Quote
Old   May 3, 2012, 11:24
Assistant Moderator
Bernhard Gschaider
Originally Posted by tfuwa View Post
Hi All,
In groovyBC this would be something like this:
valueExpression "0"; // this doesn't matter
fractionExpression "0"; // no value, all gradient
gradientExpression "sin(2*pi*time())";
Official tools: you can do something similar with some C++-programming with the codedMixed-BC I guess
Old   May 4, 2012, 09:41
Albert Tong
Thanks Bernhard! It works perfect.
Kind regards,
Albert
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 14:42
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
