Can simpleFoam calculate accurate lift coefficient for vortex shedding of cylinder? |
April 8, 2022, 06:19 |
Bushra Rasheed
Rep Power: 5 |
Hi!
For flow around cylinder at different reynold numbers, can simpleFoam give accurate lift coefficient ? For Re 200, the lift coefficient calculated by simpleFoam in my case is very low as compared to 0.7-0.8 in literature. I want to know how simpleFoam works for vortex shedding, why is it capturing vortex shedding with time even thoguh it's a steady solver and whether the lift coeffcient calculated through simpleFoam is accurate or not. I can't use icoFoam since it's taking too long. Please guide Thanks |
flow around cylinder, lift coefficent, simplefoam, vortex shedding, vortex shedding openfoam |
How to calculate predominant shedding frequency in Strouhal Number | HappyS5 | OpenFOAM Running, Solving & CFD | 31 | April 4, 2022 04:33 |
Oscillation in lift coefficient plot | hsuam | FLUENT | 0 | May 1, 2021 17:31 |
oepnfoam naca0012 I can not get the correct lift coefficient and drag coefficient | cheng1 | OpenFOAM | 4 | April 19, 2021 23:43 |
Lower Lift coefficient value | goutamp | FLUENT | 3 | December 12, 2020 16:31 |
Lift Cylinder in Liquid using ANSYS | MikeShuo | Main CFD Forum | 0 | October 24, 2016 01:46 |
