OF 2.x, cyclic boundary and MRFSimpleFoam compatibility |
January 8, 2012, 13:34 |
Jean-Michel FONTAINE
Rep Power: 16 |
Hello dear forum
Did anybody experiment OF 2.1.0 with cyclicAMI boundaries and MRFSimpleFoam ? Is it supposed to work ? I used to do that with OF 1.5-dev. I'm testing OF 2.1.0, from RPM packages for SUSE. I get following error : Code:
Reading field p Reading field U AMI: Creating addressing and weights between 10342 source faces and 13525 target faces AMI: Patch source weights min/max/average = 6.7415422e-14, 1.2787833, 1.0003003 AMI: Patch target weights min/max/average = 0, 1.2746978, 1.0002249 Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model kOmegaSST #0 Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib64/libc.so.6" #3 Foam::FaceCellWave<Foam::wallPoint, int>::updateFace(int, Foam::wallPoint const&, double, Foam::wallPoint&) in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libmeshTools.so" #4 Foam::FaceCellWave<Foam::wallPoint, int>::handleAMICyclicPatches() in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libmeshTools.so" #5 Foam::FaceCellWave<Foam::wallPoint, int>::iterate(int) in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libmeshTools.so" #6 Foam::patchWave::correct() in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libmeshTools.so" #7 Foam::patchWave::patchWave(Foam::polyMesh const&, Foam::HashSet<int, Foam::Hash<int> > const&, bool) in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libmeshTools.so" #8 Foam::wallDist::correct() in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #9 Foam::wallDist::wallDist(Foam::fvMesh const&, bool) in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #10 Foam::incompressible::RASModels::kOmegaSST::kOmegaSST(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&, Foam::word const&) in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so" #11 Foam::incompressible::RASModel::adddictionaryConstructorToTable<Foam::incompressible::RASModels::kOmegaSST>::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so" #12 Foam::incompressible::RASModel::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so" #13 in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/MRFSimpleFoam" #14 __libc_start_main in "/lib64/libc.so.6" #15 at /usr/src/packages/BUILD/glibc-2.11.3/csu/../sysdeps/x86_64/elf/start.S:116 Exception en point flottant Thanks in advance, and best wishes Jean-Michel PS : many thanks and congratulations to OF maintainers team for the last evolutions of the software : AMI, edges in SHM, packaging |
January 9, 2012, 14:24 |
Michael Ahlmann
Rep Power: 16 |
I configured a cyclicAMI case last weekend (using rotationally cyclic boundary conditions), and it seemed to work smoothly. Granted, I'm having convergence issues with MRFSimpleFoam, but I'm fairly certain it's a setup issue and has nothing to do with the AMI implementation (It's looking like the boundary patches need to be further offset from the rotating features).
Can you provide more detail on your case? Perhaps post the case files if they aren't too big? |
January 9, 2012, 15:22 |
[SOLVED] cyclicAMI + MRFSimpleFoam crash
Rep Power: 16 |
Hi Mickael
Thanks for your attention. Finally I found the fix on the forum. Running following command did the job : Code:
unset FOAM_SIGFPE This forum is very good. Thanks to everybody Regards jean-Michel |
May 23, 2012, 10:10 |
Forrest
Rep Power: 14 |
It doesen't work...just there was not the warning ,but can't calculate.
May 24, 2012, 04:01 |
Forrest
Rep Power: 14 |
July 29, 2012, 01:51 |
plz tell me it is true???or not???
vahid
Rep Power: 13 |
hi Dear Foamers.
I want to add k(kinetic turbulence energy) in one solver. for this reason added this line in code : const volScalarField &k=U_.db().lookupObject<volScalarField>("k") and wmake was Successfully . but How can I Understand that this k is the same with k(kinetic turbulence energy)???Is it true????? Because I replase another world in this : const volScalarField &M=U_.db().lookupObject<volScalarField>("M") but not error occured!!!!!!?????? |
cyclic boundaries, mrfsimplefoam |
MRFSimpleFoam: wrong boundary conditions on rotating walls | cves | OpenFOAM Bugs | 3 | May 3, 2010 03:38 |
case with cyclic boundary | openfoam_user | OpenFOAM Running, Solving & CFD | 0 | March 26, 2010 07:46 |
cyclic BC - createPatch | AirS | OpenFOAM | 7 | November 12, 2009 10:04 |
Cyclic boundary conditions axisymmetric | gabriel | OpenFOAM Running, Solving & CFD | 0 | July 27, 2007 11:24 |
[OpenFOAM] View cyclic boundaries using MRFSimpleFoam | gabriel | ParaView | 0 | July 27, 2007 08:42 |
