simpleFoam convergence problems for pipe flow problem
Old   January 30, 2012, 14:40
Default simpleFoam convergence problems for pipe flow problem
Mike Graham is on a distinguished road
I've been solving some very simple pipe flow problems using 1.6-ext's simpleFoam with a k-epsilon turbulence model and have had trouble getting good results. As I let my simulation go, in many time steps the p equation solver maxes out the number of iterations required before moving on (I've tried 1000 maximum for GAMG, 2500 for PCG), and eventually the pressures and velocities get huge and the continuity error gets large and the simulation dies due to a SIGFPE.
I've adjusted my p solver and parameters, my grad(p) schemes and various divSchemes, my relaxation parameters, and my initial conditions, but the solution inevitably blows up. If I change my boundary conditions to inlet-pressure/outlet-velocity or pressure/pressure, I don't blow up, but I do not achieve convergence.
Can anyone explain why I'm having trouble or advise me how to proceed?
One case that I ran is posted at http://dl.dropbox.com/u/19693178/examplecase.tar.gz
Here are some of my input files
0/fvSolution
solvers
    p
        solver           GAMG;
        tolerance        1e-6;
        relTol           0;
        smoother         GaussSeidel;
        nPreSweeps       0;
        nPostSweeps      2;
        cacheAgglomeration on;
        agglomerator     faceAreaPair;
        nCellsInCoarsestLevel 10;
        mergeLevels      1;
    U
        solver           smoothSolver;
        tolerance        1e-8;
        relTol           0.1;
        nSweeps          1;
    k
        tolerance        1e-8;
        relTol           0.1;
        nSweeps          1;
    epsilon
        tolerance        1e-8;
        relTol           0.1;
        nSweeps          1;
SIMPLE
    nNonOrthogonalCorrectors 0;
relaxationFactors
    p               0.3;
    U               0.6;
    k               0.2;
    epsilon         0.2;
fvSchemes
ddtSchemes
    default steadyState;
gradSchemes
    default         Gauss linear;
    grad(p)         cellLimited Gauss linear 1;
    grad(U)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss linearUpwindV Gauss linear;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon)  Gauss upwind;
    div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
fluxRequired
    default         no;
    p;
0/U
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    Inlet
        type            fixedValue;
        value           uniform (-1.68669369 -7.75789138 0);
    Outlet
        type            zeroGradient;
    Sym
        type            symmetryPlane;
    Wall
        type            fixedValue;
        value           uniform (0 0 0);
0/p
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    Outlet
        type            fixedValue;
        value           uniform -29.89;
    Inlet
        type            zeroGradient;
    Wall
        type            zeroGradient;
    Sym
        type            symmetryPlane;
0/k
internalField   uniform 90.583e-6;
boundaryField
    Inlet
        type            fixedValue;
        value           $internalField;
    Outlet
        type            zeroGradient;
    Wall
        type            kqRWallFunction;
    Sym
        type            symmetryPlane;
0/epsilon
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 12.89e-6;
boundaryField
    Inlet
        type            fixedValue;
    Outlet
        type            zeroGradient;
    Wall
        type            epsilonWallFunction;
    Sym
        type            symmetryPlane;
0/nut
dimensions      [0 2 -1 0 0 0 0];
boundaryField
    Inlet
        type            calculated;
        value           uniform 0;
    Outlet
        type            calculated;
        value           uniform 0;
    Wall
        type            nutWallFunction;
        value           uniform 0;
    Sym
        type            symmetryPlane;
Mike Graham is offline   Reply With Quote
Convergence Problem icoFoam steady flow over an airfoil Lucas OpenFOAM Running, Solving & CFD 6 July 12, 2018 15:06
Multiphase Flow - Convergence Problems bastian26 FLUENT 0 September 19, 2011 07:26
Convergence problem with simpleFoam solver on tilted channel daev OpenFOAM Running, Solving & CFD 1 December 23, 2010 16:20
Problem in convergence for simulate wind flow around building lalula2 FLUENT 2 June 8, 2009 03:13
Transient flow convergence problems Syed Mohammed Qamar Hasnain Siemens 0 March 20, 2007 06:17
