February 26, 2012, 14:56 |
porousSimpleFoam crash on 40 cores
Marco
Rep Power: 14 |
I'm running a simulation with porousSimpleFoam. The simulation executed on 7 cores converges after 1295 iterations, but if I try to run the same simulation on 40 cores it diverges after 96 iterations. Is there any mathematical reason for this? If yes, there is a way to calculate the max number of cores that can be used? Thanks to all. Marco |
February 26, 2012, 16:09 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Marco,
My experience on this is limited, but AFAIK, there are several hypothesis for the crash, since you didn't give any specifics about the case. Some examples:
Bruno
February 26, 2012, 17:22 |
#3 | |
Arjun
Rep Power: 34 |
But I am not sure if it is the case. What was your pressure correction solver. If it was multigrid then it is possible to crash or diverge. If it was Kyrlov based solver like conjugate gradient then less likely but still depends on preconditioner used. |
Specify number of cores that CFX should use. | Lance | CFX | 16 | July 20, 2016 09:04 |
Which is better for CFD 4 core i7-2600 or AMD 8 core FX-8150? | GregShaffer | Hardware | 3 | May 7, 2015 13:26 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
porousSimpleFoam - crash | Sebaj | OpenFOAM | 2 | January 4, 2012 16:16 |
Selecting cores independently in a dual quad core machine | jalarron | FLUENT | 1 | September 7, 2009 17:06 |
