Metis on OF 2.0.0
Old   February 29, 2012, 06:28
Default Metis on OF 2.0.0
pere
pere is on a distinguished road
I've compiled Of 2.0.0 in a Altix 1000 all works fine but when I try to use metis decomposition. This error appears, I've just modified decomposeParDict:
--> FOAM FATAL ERROR:
You are trying to use metis but do not have the metisDecomp library loaded.
This message is from the dummy metisDecomp stub library instead.
Please install metis and make sure that libmetis.so is in your LD_LIBRARY_PATH.
The metisDecomp library can then be built from $FOAM_SRC/parallel/decompose/metisDecomp and dynamically loading or linking this library will add metis as a d
ecomposition method.
Please be aware that there are license restrictions on using Metis.
From function labelList metisDecomp::decompose(const pointField&, const scalarField&)
in file dummyMetisDecomp.C at line 108.
FOAM exiting
After that I have downloaded Metis and I have compiled it in ThirdParty directory, and I have added libmetis.so in LD_LIBRARY_PATH.
And the same error appears.
Did anyone knows how can I do for use metis decomposition?
Thanks in advance!
Pere
pere is offline   Reply With Quote
metis decompose OpenFoam 2.0.0 sebastianweiper OpenFOAM Installation 11 December 29, 2020 11:59
OpenCFD release OpenFOAMŪ version 2.0.0 opencfd OpenFOAM Announcements from ESI-OpenCFD 1 July 1, 2011 08:43
How to partition EDGES by using METIS Lupocci Main CFD Forum 0 August 18, 2010 17:43
Problem with Partitioners (METIS) Partition ANSYS Meshing & Geometry 1 January 1, 2010 13:53
Node numbering at interface in MeTiS. mehul Main CFD Forum 0 December 19, 2006 10:21
