March 20, 2022, 17:03 |
SimpleFoam diverge problem
zian cheng
I am trying to simulate the wind around a cube using the k-omega SST model to get the C_p value around the cube. When I run the solver, divergency happens after hundreds of timesteps, and I got high timestep errors, this is the error I got: Time = 512 smoothSolver: Solving for Ux, Initial residual = 0.076812, Final residual = 6.03472e-07, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.077275, Final residual = 9.05036e-07, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.0608148, Final residual = 6.76609e-07, No Iterations 4 GAMG: Solving for p, Initial residual = 4.63556e-06, Final residual = 7.43667e-07, No Iterations 2 GAMG: Solving for p, Initial residual = 6.24736e-07, Final residual = 6.24736e-07, No Iterations 0 time step continuity errors : sum local = 31338.4, global = 1258.35, cumulative = 14145.1 smoothSolver: Solving for omega, Initial residual = 0.0005501, Final residual = 1.36789e-07, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.104849, Final residual = 8.41271e-07, No Iterations 3 bounding k, min: -6664.56 max: 3.28718e+25 average: 1.24281e+19 ExecutionTime = 1555.62 s ClockTime = 1559 s I think most likely the problem is in boundary conditions but I still attached my mesh check file, any idea where should I look into it? The bounding K seems to be a problem, should I just look at the boundary condition for k or U and omega as well? A lot of thanks. Regards, Zian |
openfoam, simple algorithm, timestep error |
Problem with simpleFoam, laminar pipeCyclic | fantaste | OpenFOAM Running, Solving & CFD | 0 | January 14, 2015 03:37 |
Problem in running simpleFoam tutorial | Lana | OpenFOAM Running, Solving & CFD | 1 | April 10, 2013 11:08 |
SimpleFoam For cavity Problem | himanshu28 | OpenFOAM | 1 | January 16, 2013 01:49 |
simpleFoam: Problem with k-omega Model near Wall | okroud | OpenFOAM Running, Solving & CFD | 0 | June 13, 2012 10:13 |
SimpleFoam convergen problem | maolongliu | OpenFOAM | 7 | August 13, 2010 10:17 |
