Setting BCs for Riverine Flows using Interfoam
Like Tree21Likes
Old   June 2, 2013, 05:59
Default manning's roughness coefficient in OpenFoam
  #21
ali naqi mohammadi
ali naqi is on a distinguished road
Originally Posted by trinath2rao View Post
Dear Foamers,
I am working on dambreak flow in an open channel. can any one help me how to specify manning's roughness coefficient in OpenFoam.
I checked manual and code, no success.
Is there anyway to specify bottom friction in OpenFoam ?
Thank You in advance.
Regards,
Trinath Rao
hi ,in the OF you should obtain roughness effect by Ks and Cs. you may find them in nut. for example:
walls
type nutkRoughWallFunction;
value uniform 0;
Ks uniform .0014;
Cs uniform .5;
ali naqi is offline   Reply With Quote
Old   April 25, 2014, 10:47
Benjamin
Benji is on a distinguished road
Hey all,
I'm working at a similar problem at the moment and hope anyone could help me. I have a free surface flow channel with a narrowing. Like before I want to give the inlet velocity (here 0.5 m/s), but I need to give a predefined outlet-pressure somehow (because I need to be able to calculate for a given water elevation at the outlet).
I thought I couldn't define a pressure for the whole outlet, so I chose to define it only at the bottom of the river bed (over the last m of the channel before the outlet). The idea was to be able to give a certain hydrostatic pressure at the ground, which should define the water level.
  • Inlet: alpha = fixedValue (1), U = fixedValue (0.5 0 0), p_rgh = fixedFluxPressure (0)
  • Outlet: alpha = inletOutlet (0), U = pressureInletOutletVelocity (0 0 0), p=fixedFluxValue (0)
  • Outlet (bottom): p = phaseHydrostaticPressure;
    phaseName alpha.water;
    rho 1000;
    pRefValue 3000;
    pRefPoint (0 0 0);
    value uniform 0;
I wasn't sure how to define that, has anyone ever tried this or would do it for me? Or are there other solutions? I also get problems with alpha reflecting at the outlet sometimes...
Casefiles (currently negative x-axis, to avoid the problem of reflecting -.-):
Thanks and have a nice WE,
Benji
Benji is offline   Reply With Quote
Old   November 5, 2014, 06:07
Default fixed depth water at outlet
  #23
ali naqi mohammadi
for implementation of fixed depth at outlet, first you should divide the mesh block into two blocks: one with height of the outlet depth and the other for air.
so we will have two outlet: waterOutlet and airOutlet.
zeroGradient boundary condition for waterOutlet .
atmosphere boundary condition for airOutlet.
Mahmoud Abbaszadeh likes this.
Old   November 5, 2014, 07:17
Albrecht vBoetticher
vonboett is on a distinguished road
Hi Benji,
have you tried just
outlet
type buoyantPressure;
value uniform 0;
for p_rgh ?
vonboett is offline   Reply With Quote
Old   November 10, 2014, 04:49
Antonio
avigrod is on a distinguished road
Hi Benji,
Have you tried Kflora suggestion. I have used in some steady open flows succesfully. I would suggest to enlarge the end of the channel to reduce influence of using a uniform 1D velocity profile.
Her suggestion is to use a fixed velocity bc of water flow rate input/ water depth aim. Being it applied to all the outlet surface (water and air)
Originally Posted by Benji View Post
Hey all,
    rho 1000;
    pRefValue 3000;
    pRefPoint (0 0 0);
    value uniform 0;
Benji
avigrod is offline   Reply With Quote
Old   January 11, 2016, 01:17
Fatemeh
fatemehfarshi62 is on a distinguished road
Hi every one!
I have a similar problem.
I have a 3D open channel which has a curved route. I want to enter a fully developed flow in the inlet and don't know how it will be at the outlet.
can any one tell me what are the right boundary conditions for inlet, outlet and free surface? thanks a lot.
Bashar likes this.
fatemehfarshi62 is offline   Reply With Quote
Old   February 11, 2017, 12:50
Bashar
Bashar is on a distinguished road
Originally Posted by fatemehfarshi62 View Post
Hi every one!
I am facing similar issues, I am working of flow past plate . Did you mamnge to make this work for you ?
Bashar is offline   Reply With Quote
Old   February 11, 2017, 23:42
Fatemeh
Originally Posted by Bashar View Post
Hi! for velocity, enter flowRateInletVelocity for inlet and inletOutlet for outlet.
for Pressure, zeroGradient for inlet and fixedValue for outlet.
Bashar likes this.
Old   February 11, 2017, 23:50
Default Setting BCs for Riverine Flows using Interfoam
  #29
Bashar
Thanks a lot for the info.Will be ok for you to share the case file ?
But thanks anyway,I will try your BC.I am using single inlet patch,I saw some cases where they use two separate inlet patches,one for air and the other for water. Did you use single inlet?
Thanks
Sent from my iPhone using CFD Online Forum mobile app
Old   February 12, 2017, 00:23
Fatemeh
No, I just have one inlet.
Bashar likes this.
Old   February 12, 2017, 00:29
Bashar
Thanks , I will try it .
Old   February 14, 2017, 15:18
Bashar
Sorry to bother you again . I have another question, if I used single inlet patch for the channel, is there away to specify the speed of the air? I am currently specifying only one speed which is the water speed.So, the water and the air will have same speed, but I want to know how I can give them different speed while using one inlet patch.
Also, what setting should alpha.water get, i.e. BC.
Bashar
Old   September 13, 2018, 07:18
Default Channel Flow Depth outlet BC - resurrected
  #33
Jeff DeGraff
jdegraff is on a distinguished road
An old post with a lot of good information.
I am modeling a river and would like to know if there are any additional tips on setting the downstream flow depth. I used Kflora's work around for simple rectangular channels but would like to know if there are work arounds for irregular shapes.
jdegraff is offline   Reply With Quote
Old   September 13, 2018, 08:26
Honza Höll
indy07cz is on a distinguished road
Maybe a good option is to make river a little bit longer (to the point where results from new cross section dont influence results in the initial location of downstream BC) and there use regular shape.
indy07cz is offline   Reply With Quote
Old   September 18, 2018, 14:13
Jeff DeGraff
indy07cz - Good suggestion. That worked for most cases.
Now what I am finding is that there isn't a constant inlet flow. I tried setting the inlet alpha to 0 (all water) but found that I still get "separation" in the stream.
Does anyone have any suggestions?
Old   September 20, 2018, 11:35
Lightbulb
  #36
Jeff DeGraff
This was a good idea which lead me to another idea. OpenFOAM V2 does not appear to be "good" at determining a proper inlet and outlet boundary condition (fixedFluxpressure, Volumetric Inlet flow) for complex geometries. But it does a decent job for simple geometries such as a rectangle. Thus I added a rectangular channel far enough upstream and downstream so that it doesn't effect the solution. Once I feel comfortable with the results, I will post them.
Again, if there is a better way of defining boundary "open channel flow" boundary conditions, please let me know. I feel that there is a lot of Foamers that deal with this issue.
Old   October 19, 2021, 10:38
In case you are using atmosphere boundary conditions for the top, make sure the water does not contact it. Single drops are OK but interFoam can't handle the water/air density difference at the atmospheric boundary condition.
Old   October 19, 2021, 10:44
By the way, I use fixedFluxPressure with complex inlet geometries, combined with fixedValue at the inlet and inletOutlet at the outlet for U. For the atmospheric top I use totalPressure with the corresponding settings and pressureInletOutletVelocity. It works well for mountain torrents
Old   July 27, 2022, 06:51
Mahmoud
Mahmoud Abbaszadeh is on a distinguished road
Have you tried this actually? This has not solved the problem in my case
Mahmoud Abbaszadeh is offline   Reply With Quote
interfoam, openfoam, river, vof
Setting up interFoam for sloshing santiagomarquezd OpenFOAM Running, Solving & CFD 2 August 11, 2017 04:08
[ICEM] Setting the BCs sreekargomatam ANSYS Meshing & Geometry 1 July 12, 2011 19:28
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
BC's for free flows kev FLUENT 0 November 8, 2005 23:02
Warning 097- AB Siemens 6 November 15, 2004 04:41
