SOS: the nonpositive k and epsion ,how to get the correct boundary settings
Old   March 6, 2012, 00:36
Default SOS: the nonpositive k and epsion ,how to get the correct boundary settings
zdong
abbott.hn is on a distinguished road
hello everybody,when i try to simulation the pantograph wind tunnel experiment,i got an divergent k and epsilon using simpleFoam or pimpleFoam with k-e turbulent modle.
i have looked though the forum a long time for a solution to this kind of divergent probelm, after changing some related settings follow the tips i got,
like checking the model length dimension ,setting the proper magnitude of k and e whenever in the internal field or boundary,setting the relax factor or tolerence
for u and p,changing the numerical scheme for k and e , even modifying the solver for k and e,
however ,all of this didn't change anything
the keypoint should be in the boundary settings,because when i turned off the turbulent modeling, the procedure can run smoothly.
those in the attachment is my cas directory , the grid is not in the constant/polyMesh but the boundary dictionary for the file size consideration.
anyone could help me out?
best regards for you,thanks .
abbott
abbott.hn is offline   Reply With Quote
Old   March 6, 2012, 02:00
Bernhard
Bernhard is on a distinguished road
I cannot run your case without the mesh, so it is difficult to spot the error. Can you give the log file? Does it diverge in the first time-step, or only later on? Is your mesh ok (check with checkMesh)?
Bernhard is offline   Reply With Quote
Old   March 7, 2012, 21:53
zdong
hello Bernhard thanks for your reply ,
the log file is in the attachments ,maybe you can find some hints from that .appreciate for your help
Old   March 10, 2012, 09:11
zdong
come on ....
i need you help .
Even when i chang to the rhoSimplecFoam solver,the problem arise the same,and this time ,the "floating points excepting " error came out at the first iterate when solving the pressure eqution,while the simpleFoam or pimpleFoam prompt the bounding turbulent energy and e at the first iterate ,and then the "floating points excepting " error after several iterate.
i will to be crazy ,foamers ,please help me out, thanks so much
Old   March 12, 2012, 02:28
romant's Avatar
Roman Thiele
romant is on a distinguished road
Originally Posted by abbott.hn View Post
come on ....
i need you help .
Hej,
first of all calm down, you cannot expect people to answer within minutes. this is a forum of volunteers not your microsoft helpdesk hotline.
Second, please check your epsilon and k values, inlet and initial. they seem very high. I don't know what you are simulating, but your values are very large. check the tutorial for values that are more appropriate. k = 0.01 and epsilon = 0.5 and then start varying those values towards what ever you expect to have for your k and epsilon values.
try to run the simulation with "standard" values first, as for example the values that are used in the tutorials
~roman
romant is offline   Reply With Quote
Old   March 12, 2012, 22:49
Default thank for you advice
zdong
Originally Posted by romant View Post
Hej,
hi
thanks for your advice ,i will follow your suggest.
i'a really a lit impatient, however, i will calm myself down and study the tutorials mor carefully.thanks .
