Get output of time derivative
Like Tree1Likes
  • 1 Post By alberto
Old   November 18, 2011, 16:49
Default Get output of time derivative
Vishal Nandigana
nandiganavishal is on a distinguished road
Dear Foamers,
I would like to know, if we can get the time derivative of a variable as the output. For instance, if I am solving the transient Navier Stokes, is it possible to get the acceleration (du/dt) too at every time step as an output.
Kindly let me know.
Regards
Vishal Nandigana
nandiganavishal is offline   Reply With Quote
Old   November 20, 2011, 20:47
Alberto Passalacqua
Use fvc::ddt(yourField) to store it in a volField of the same type of your field. Setting the IOobject to AUTO_WRITE will have the time derivative stored.
Alberto Passalacqua
Old   November 21, 2011, 11:45
Vishal Nandigana
Thanks Alberto. It worked well.
Old   March 14, 2012, 12:53
Andrea Ferrari
Andrea_85 is on a distinguished road
how can i get the same in a postprocessing? If i use this code:
read U
read rho
volVectorField ddt
IOobject
"ddt",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
fvc::ddt(rho,U)
ddt.write()
it returns always zero.
best
andrea
Andrea_85 is offline   Reply With Quote
Old   March 14, 2012, 13:04
Alberto Passalacqua
Originally Posted by Andrea_85 View Post
read U
read rho
volVectorField ddt
IOobject
"ddt",
runTime.timeName(),
mesh,
IOobject::NO_READ,
fvc::ddt(rho,U)
ddt.write()
best
andrea
If you only declared the field in createFields.H, it is normal. You have to
a) declare the field as you did in createFields.H
b) add the line
ddt == fvc::ddt(rho,U);
at the end of pEqn.H, so you have the corrected velocity. You do not need the .write() call if you define the field with AUTO_WRITE in the global scope.
Best,
sharonyue likes this.
Alberto Passalacqua
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
lift and drag on ship superstructures vaina74 OpenFOAM Running, Solving & CFD 3 June 8, 2010 12:30
ForcesCoeffs ronaldo OpenFOAM 4 September 14, 2009 07:11
Time derivative in transiente run Antonio Lopes CFX 2 January 12, 2008 11:03
How to output variables every time step? Dazhi Guo FLUENT 4 January 16, 2001 11:17
