June 15, 2015, 02:32 |
PyFoamPlotWatcher to plot min/max "p"
#21 |
sethu
Rep Power: 14 |
Dear all,
Im trying to plot min/max of pressure (p) in my domain using pyFoamPlotwatcher.py along with massflow rate. Im able to plot for massflow rate, but min(p) values are not getting plotted. My log file looks like this, //log_file_sample_start// ... ExecutionTime = 46.73 s ClockTime = 51 s MassFlows: outlet = 0.000254 inlet = -0.000254 fieldMinMax minmaxdomain output: min(p) = -9.27757 at position (0.0549444 -0.0108001 -1.09092e-21) max(p) = 13.3839 at position (0.207022 0.0251462 -1.63172e-21) min(U) = (9.83972 -1.23842 0) at position (-0.0198086 0.000156695 -2.90727e-21) max(U) = (10.0882 0.0457922 5.69625e-23) at position (0.000794772 0.00125782 -3.55445e-21) //log_file_sample_end// My customRegexp file is written like this, massFlow { accumulation first; enabled yes; expr "MassFlows: outlet = (%f%) inlet = (%f%)"; name Custom01_massFlow; theTitle "Massflow rate"; titles ( outlet inlet ); type regular; } min(p) { expr "min(p) = (%f%) at position \(%f% %f% %f%\)"; name Custom02_min(p); theTitle "min_p"; titles ( min_p ); type regular; } As I mentioned earlier, massflow values are plotted but min(p) value is not getting plotted. Moreover, i didnt receive any error. Pls give me your suggestions. Sethu |
July 19, 2016, 10:48 |
#22 |
ArielJ
Rep Power: 10 |
Hi, I'm having trouble using the customRegexp and swak4Foam function objects (following from one of the OFW presentation examples). I'm getting the following error when I try to run a case with some swak4Foam expressions in controlDict and a customRegexp file:
PyFoam WARNING on line 144 of file /usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/PyFoam/Execution/ParallelExecution.py : which can not find a match for waveFoam . Hoping for the best Traceback (most recent call last): File "/usr/local/bin/pyFoamPlotRunner.py", line 5, in <module> pkg_resources.run_script('PyFoam==0.6.5', 'pyFoamPlotRunner.py') File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 499, in run_script self.require(requires)[0].run_script(script_name, ns) File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 1235, in run_script execfile(script_filename, namespace, namespace) File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/EGG-INFO/scripts/pyFoamPlotRunner.py", line 5, in <module> PlotRunner() File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/PyFoam/Applications/PlotRunner.py", line 60, in __init__ **kwargs) File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/PyFoam/Applications/PyFoamApplication.py", line 424, in __init__ result=self.run() File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/PyFoam/Applications/PlotRunner.py", line 135, in run jobId=self.opts.jobId) File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/PyFoam/Execution/GnuplotRunner.py", line 171, in __init__ plottingImplementation=plottingImplementation) File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/PyFoam/Execution/GnuplotRunner.py", line 74, in __init__ plottingImplementation=plottingImplementation) File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/PyFoam/Execution/AnalyzedCommon.py", line 278, in createPlots endTime=custom.end)) File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/PyFoam/LogAnalysis/RegExpLineAnalyzer.py", line 71, in __init__ self.exp=re.compile(self.strExp,reFlags) File "/usr/lib/python2.7/re.py", line 190, in compile return _compile(pattern, flags) File "/usr/lib/python2.7/re.py", line 242, in _compile raise error, v # invalid expression sre_constants.error: unbalanced parenthesis Exception in thread Thread-3 (most likely raised during interpreter shutdown): Traceback (most recent call last): File "/usr/lib/python2.7/threading.py", line 551, in __bootstrap_inner File "/usr/lib/python2.7/threading.py", line 757, in run File "/usr/lib/python2.7/threading.py", line 403, in wait File "/usr/lib/python2.7/threading.py", line 258, in wait <type 'exceptions.TypeError'>: 'NoneType' object is not callable Code:
application waveFoam; startFrom latestTime; //startTime; startTime 0; stopAt endTime; endTime 300; deltaT 0.05; writeControl adjustableRunTime; writeInterval 0.5; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; adjustTimeStep yes; maxCo 0.9; // increase the Co as much as possible maxAlphaCo 0.9; maxDeltaT 1; // **************************************************************************** // libs ( "libOpenFOAM.so" "libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so" "libgroovyBC.so" ); functions { forces { type forces; functionObjectLibs ("libforces.so"); patches (cylinder); rhoName rho; rhoInf 1028; CofR (0 0 0); outputControl timeStep;//outputTime;// outputInterval 100; log true; } velocityStatistics { type swakExpression; verbose true; outputControlMode timeStep; outputInterval 1; valueType internalField; expression "mag(U)"; accumulations ( weightedQuantile0.1 weightedAverage weightedQuantile0.9 max ); } minStreamFunctionPos { type swakExpression; verbose true; outputControlMode timeStep; outputInterval 1; expression "streamF"; valueType internalField; accumulations ( min ); expressions "minPosition(streamF)"; } } And finally my customRegexp file is: Code:
velocity { theTitle "Velocity statistics"; expr "Expression velocityStatistics : weightedQuantile0.1=(.+) weightedAverage=(.+) weightedQuantile0.9=(.+) max=(.+)"; titles ( "10 %" average "90 %" maximum ); ylabel "[m/s]"; } I can't see an unbalanced paranthesis... can anyone help me on this? Thanks in advance |
July 21, 2016, 11:34 |
#23 |
Rep Power: 10 |
hello dear friends,
I am trying to plot the output of a faceSource functionObject that computes the total massflow at inlet. Here is my log for one timestep: Code:
PIMPLE: iteration 1 DILUPBiCG: Solving for Ux, Initial residual = 0.0116454, Final residual = 5.6463e-08, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.00353414, Final residual = 3.34245e-09, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.00429777, Final residual = 8.15157e-09, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0390386, Final residual = 0.000158842, No Iterations 4 time step continuity errors : sum local = 4.00815e-08, global = 3.11859e-13, cumulative = 1.62584e-11 DICPCG: Solving for PotE, Initial residual = 7.94541e-07, Final residual = 7.94541e-07, No Iterations 0 ExecutionTime = 5.58 s ClockTime = 6 s faceSource debit_sortant output: sum(inlet) of phi = -0.00164543 Code:
massflowplot { enabled yes; expr " sum(inlet) of phi = (%f%)"; name Custom_flow_plot; theTitle "Custom_flow_plot"; titles ( massflow ); type regular; } Code:
pyFoamPlotRunner.py mySolver But it doesn't plot and I don't understand why. Any idea ? Do I have to write something else somewere else ? Is the regexp correct ? thanks a lot for any help ! |
June 13, 2020, 11:36 |
Plotting particles added and escapes
#24 |
Hi All,
How do you get pyFoamPlotWatcher to plot the added particle count and the escape count from solver.log? The typical time step output for particles look like below: Time = 0.875 Evolving kinematicCloud Solving 3-D cloud kinematicCloud Cloud: kinematicCloud Current number of parcels = 5045 Current mass in system = 0.00647515 Linear momentum = (-0.002015723 -0.001078755 -0.0004498539) |Linear momentum| = 0.002330069 Linear kinetic energy = 0.01457947 injector_1: number of parcels added = 6546 mass introduced = 0.008395572 Parcel fate (number, mass) : patch cyclone_inletX - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch cyclone_outlet - escape = 1501, 0.001920422 - stick = 0, 0 I wrote a Python script to print to a CSV file and plot it using Gnuplot: Code:
#!/usr/bin/python import re import sys from subprocess import call if len(sys.argv) > 1 : TEXTFILE = sys.argv[1] else : TEXTFILE = 'solver.log' if len(sys.argv) > 2 : CSVFILE = sys.argv[2] else : CSVFILE = 'timeAddsEscapes.csv' f1=open(CSVFILE, 'w+') STATE0 = 'TIME' STATE00 = 'SEARCH_ADDED' STATE1 = 'SEARCH_OUTLET' STATE2 = 'SEARCH_ESCAPE' RE0 = 'Time = (\d+.\d+)' RE00 = r'.*parcels added\s*=\s*(\d+)' RE1 = r'\s*Parcel fate.*\:.*outlet$' RE2 = r'\s*-\s*escape\s*=\s*(\d+)' state = STATE0 print >>f1, "Time","Added", "Escapes" with open(TEXTFILE, 'r') as f: for line in f: if state == STATE0 : pat = RE0 elif state == STATE00 : pat = RE00 elif state == STATE1 : pat = RE1 else : pat = RE2 match = re.match(pat, line) if not match : continue #if state == STATE0 or state == STATE2 : #print line if state == STATE0 : time = float(match.group(1)) state = STATE00 elif state == STATE00 : added = int(match.group(1)) state = STATE1 elif state == STATE1 : state = STATE2 else : escapes = int(match.group(1)) state = STATE0 if added > 0 : # print "Time = ", time, " added = ", added, " escapes = ",escapes print >>f1, time, added, escapes f1.close() call(["plotEscapes.sh", CSVFILE]) Code:
#!/bin/bash if (( $# != 1 )); then echo "Illegal number of parameters" cat <<EOT Usage: plotEscapes.sh <CSV filename> EOT exit fi gnuplot -persist << EOT set term X11 size 700, 900 set title 'Particle escapes & Particles added vs Time' set xlabel 'Time/s' set ylabel 'Particle count' set grid set multiplot layout 2,1 columnsfirst plot for [i=2:3] '$1' using 1:i lt 1 with lines title columnhead at end set logscale y plot for [i=2:3] '$1' using 1:i lt 2 with lines title columnhead at end unset multiplot EOT Last edited by Mars409; June 17, 2020 at 04:45. Reason: Adding more codes. |
[PyFoam] First discussion thread about PyFoam | braennstroem | OpenFOAM Community Contributions | 338 | March 17, 2022 14:05 |
