Obtain values only at boundary during a run
Old   April 3, 2012, 14:54
Question Obtain values only at boundary during a run
Wouter
wcpvandervelden is on a distinguished road
Dear all,
For my own solver, I need to store only the pressure values at the wall (walls as specified in constant/polyMesh/boundary). This is then used as a source term for dipoles aeroacoustic sources.
I was thinking to store a new volScalarField, with the values for p on the boundary for each time step. The internal field should be zero then.
Is there a simple command to only obtain the boundary values of a volume scalar field, while the internal field should be empty/zero?
Thanks in advance,
Wouter
wcpvandervelden is offline   Reply With Quote
boundary pressure
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Use sampled data from previous run as boundary condition for new setup Arnoldinho OpenFOAM Running, Solving & CFD 3 December 6, 2012 13:16
boundary values OFU OpenFOAM Programming & Development 4 August 9, 2011 06:27
How have boundary values set for calculated variables olwi OpenFOAM Running, Solving & CFD 5 August 25, 2006 11:56
Turbulence boundary values lego Main CFD Forum 0 October 24, 2002 13:47
