Airfoil lift and drag using k-kl-omega turbulence model
Like Tree1Likes
  • 1 Post By hylleman
Old   August 11, 2014, 03:15
Smile Airfoil lift and drag using k-kl-omega turbulence model
Karl Hylen
hylleman is on a distinguished road
Hi FOAM:ers,
I'm trying to get nice lift/drag prediction on 2D airfoils at low AoA:s (0-5 degrees) and a Re of 10^6, using the simpleFoam solver. I've used some low-Re turbulence models, especially SST k-omega, and some different meshes, but am consequently getting to high drag, an overprediction of 100-150%. From the threads here on this subject I understand that this is normal for fully turbulent modells, and that a transitional model may be needed.
Thus I have now turned to the kklomega model, which I believe is the only transitional model implemented in OpenFOAM. The problem is that I can't even get this model to run. In the first iteration, the solver ends with a floating point exception. I would very much appriciate help on making this case run.
These are my BC:s,
Kt:
inlet fixedValue 3.4e-4
outlet inletOutlet inletValue 3.4e-4
airfoil fixedValue 1e-11
Kl:
inlet fixedValue 1e-11
outlet inletOutlet inletValue 1e-11
omega:
inlet fixedValue 0.25
outlet inletOutlet 0.25
airfoil omegaWallFunction
nut:
inlet/outlet calculated
airfoil nutLowReWallFunction
p:
inlet zeroGradient
outlet fixedValue 0
airfoil zeroGradient
U:
inlet fixedValue (15.11 0 0)
outlet inletOutlet inletValue (15.11 0 0)
airfoil fixedValue (0 0 0)
These are my numerical schemes,
divSchemes
default none;
div(phi,U) bounded Gauss limitedLinearV 1;
div(phi,kt) bounded Gauss limitedLinear 1;
div(phi,kl) bounded Gauss limitedLinear 1;
div(phi,omega) bounded Gauss limitedLinear 1;
div((nuEff*dev(T(grad(U))))) Gauss linear;
I've been using this wonderful mesher by Mads here on the forum,
http://hvirvel.dk/airfoilmesher/
Should probably also mention that I'm using OpenFOAM 2.3.0. I would very much appriciate help on making this case run.
Regards,
Karl
EDIT: After reading the article a bit closer, I changed omega to zeroGradient at the airfoil. Not the problem though.
EDIT2: The error message might be helpful. It suggests a division by zero in the kklomega::correct function, if I understand it correctly. I cannot see what might be zero at the start though...
smoothSolver:  Solving for Ux, Initial residual = 0.020463, Final residual = 0.00138025, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.0726345, Final residual = 0.00486526, No Iterations 1
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.00940194, No Iterations 2
time step continuity errors : sum local = 0.00295125, global = -1.54808e-06, cumulative = -1.54808e-06
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/usr/lib/libc.so.6"
#3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4  void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#5  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#6  Foam::incompressible::RASModels::kkLOmega::correct() at ??:?
 in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/simpleFoam"
#8  __libc_start_main in "/usr/lib/libc.so.6"
hylleman is offline   Reply With Quote
Old   August 15, 2014, 02:13
Karl Hylen
I managed to get this working, after a lot of fiddeling. Unfortunatly, I can't say exactly what the problem was since I changed a lot (schemes, bcs, relaxation factors...). Now I get really nice force prediction on the airfoil, so the fiddeling was worth it
tareqkh likes this.
Old   August 20, 2014, 05:32
Michael D.
MichaelD is on a distinguished road
Hi Karl,
I'm also interested in trying the kklomega model, and I've run into the same problem. Could you post the setup you used to get it working?
Thanks in advance!
MichaelD is offline   Reply With Quote
Old   November 29, 2014, 22:20
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hey,
Could you please provide us more explications since I am working on the same problem?
tareqkh is offline   Reply With Quote
Old   February 5, 2015, 07:52
Anonymous
papercut is on a distinguished road
I get the same instant error
Anyone knows how to deal with this?
papercut is offline   Reply With Quote
Old   February 5, 2015, 11:01
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
If you take a look at correct method of kkLOmega, programming there always is rather defensive, like this:
const volScalarField lambdaT(sqrt(kT)/(omega_ + omegaMin_));
to avoid division be zero. Except several places, here's one of them:
    const volScalarField nutl
        min
            C11_*fTaul(lambdaEff, ktL)*omega*sqr(lambdaEff)
          * sqrt(ktL)*lambdaEff/nu()
          + C12_*BetaTS(ReOmega)*ReOmega*sqr(y_)*omega
            0.5*(kl_ + ktL)/sqrt(S2)
where S2 is
const volScalarField S2(2.0*magSqr(symm(gradU)));
Why your S2 goes to zero somewhere? I don't know, can you show your initial and boundary conditions?
Update. Though if you have got diverging solution and something that should be positive has become negative, then all these omega_ + omegaMin_ can become zero.
alexeym is offline   Reply With Quote
Old   June 17, 2016, 15:10
Default New model
Alberto
malv83 is on a distinguished road
After 8 years, there is a new version (or new model) of the k-kl-omega model.
There are a few problems with the k-kl-omega model in the farfield. One of them is the growth of Laminar Kinetic energy when separation occurs. Lopez and Walters have a paper (have not been published yet) correcting this issue:
Maurin Lopez. D. K. Walters. “A recommended correction to the k-kl-omega transition sensitive eddy-viscosity model”. Journal of Fluid Engineering.
This correction has to be made to the 2008 k-kl-omega model from now on.
Now, Lopez and Walters also developed a new transitional model (k-omega-v2) as an alternative to the k-kl-omega one. This new model has more capabilities (it is more reliable) than the k-kl-omega model, especially in the farfield computations. Fortunately the paper for this new model is already publish.
Maurin Lopez. D. K. Walters. “Prediction of transitional and fully turbulent free shear flows using an alternative to the laminar kinetic energy approach”. Journal of Turbulence, Vol 17, Iss. 3, 2016.
If you see the papers, you will immediately see how the k-kl-omega model is not good for free shear flows, and how the new model corrects all those issues. From now on, k-kl-omega users have to start using the new k-omega-v2 model.
malv83 is offline   Reply With Quote
airfoil, drag, kklomega, lift, simplefoam
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 05:18
Airfoil lift and drag understimated Kio OpenFOAM Pre-Processing 15 October 1, 2016 13:48
S-A Turbulence Model and drag prediction Alan FLUENT 2 January 11, 2016 08:33
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 09:26
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
