February 10, 2016, 11:11 |
interfoam problem for airfoil above water
esmaeil
Rep Power: 12 |
hi
I want to validate Cl for an airfoil above free surface of water. Im using interfoam solver to simulate multiphase flow. in my case airfoil is in air phase so I expect that the lift coefficient will be near lift coefficient of airfoil in free stream air. but results was extremely different and the lift coefficient is near lift coefficint of a foil in water... when I run the case that is far from the free surface and actually simulation is single phase (air) the resulats are near the article. I appreciate any suggestion or advice. thank you |
(interfoam) shear stress at water air interface ! | openfoam1 | OpenFOAM | 11 | October 27, 2014 03:59 |
very simple problem with interFoam | seju | OpenFOAM Programming & Development | 4 | August 13, 2014 12:36 |
very simple problem with interFoam | seju | OpenFOAM | 0 | June 10, 2014 05:13 |
Free Surface problem for a multiphase liquid mixture in a water tank | UDS_rambler | Fluent Multiphase | 0 | May 20, 2014 10:05 |
interFoam problem: Movement in wrong direction | u2947 | OpenFOAM Running, Solving & CFD | 0 | June 17, 2013 06:29 |
