The Umean of a flow around a cube calculated in Openfoam looks like instantaneous |
June 14, 2016, 16:31 |
Rep Power: 10 |
Hi, everyone
I'm trying to study the flow features around a cube placed in an uniform flow (without walls). However, the mean velocity calculated in Openfoam is just like instantaneous, and differs with time. I have uploaded the streamline (surfaceLIC) of Umean colored by magnitude in X-Z plane through the center line at different times, 4.74s, 6.98s and 8.1s. X is the streamwise direction, Y is the spanwise direction and Z is vertical in the cross-stream direction. What's more, flow characteristics in X-Y plane is not the same as X-Z plane. The time is long enough and the flow is statistical steady, since the mean value of Cd, Cl and Cs is steady as shown in attached pictures, in which these parameters are averaged every 1s. Have anyone encounter similar questions or could anyone give me some advice? The phenomenon confused me a lot and I can't validate my case due to the lack of related experimental study. Thank you very much! Best regards Yanan |
June 14, 2016, 17:04 |
#2 | |
Eric Robertson
Rep Power: 14 |
June 14, 2016, 17:11 |
Rep Power: 10 |
Yes I use the command "vorticity -latestTime" in openFoam to calculate the vorticity. And sorry for the misunderstanding description in the question. The "vorticity" in the question means constant recirculation region.
June 14, 2016, 17:13 |
Rep Power: 10 |
June 14, 2016, 17:16 |
Rep Power: 10 |
cube flow |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
Simulating Creeping (Stokes) Flow in OpenFOAM | shanleyk | OpenFOAM Running, Solving & CFD | 3 | July 9, 2015 15:41 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
Flow visualization vs. Calculated flow patterns | Francisco Saldarriaga | Main CFD Forum | 1 | August 2, 1999 23:18 |
