interFoam, water flowing down a curved surface: is it correct?
Old   March 2, 2017, 06:47
Default interFoam, water flowing down a curved surface: is it correct?
Enrico Bezzi
be89 is on a distinguished road
I'm simulating a multiphase air-water problem where water is flowing down a rectangular pipe onto a curved surface while filling a tank (see attached pictures).
I'm not sure about the shrinkage down the curved surface...is it correct?
I would expect the flow to get wider, not thinner.
What do you think about it?
Solver is interFoam, gravity is present and surface tension sigma is 0.07 N/m.
be89 is offline   Reply With Quote
Old   March 2, 2017, 06:55
RK_Token
RK_Token is on a distinguished road
Looks correct for me. The flow gets accelerated, hance the volume flow rate increases sind therfore the cross section needs to decrease to fulfil continuum condition. Its Like water flow Out oft a water tap.
Sent from my ONEPLUS A3003 using CFD Online Forum mobile app
RK_Token is offline   Reply With Quote
Old   April 21, 2017, 13:22
Saideep
Saideep is on a distinguished road
In your second figure it is a bit interesting that you see a completely smeared out volume fractions. In reality alpha is 1 or 0 and in a few cells in-between 0 and 1. Looking at the figure I guess you use a coarser mesh may be it is important you resolve it more finer from my perspective.
Else, I have tried interFoam on a microchannel with small heights around 10 microns. I did see similar sort of interface smearing. Later I shifted to Foam-Extend 1.6 which solved this issue.
Saideep
Saideep is offline   Reply With Quote
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
swimming pool water surface motion due to wind J.Kim FLUENT 4 May 5, 2006 10:08
Make a simulation of water flowing into a vase !?? Vu Trinh Tuan CFX 7 April 6, 2005 14:23
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
